Am I experiencing an issue?
Old Aug 23, 2013 | 01:59 AM
Drac0nic's Avatar
I'm just looking for a basic sanity check here, I have been dealing with tuning issues that have been anything but and want a clear perspective.
First off, probably should elaborate a bit on my combo. I have an L03 with ported 416es on it (done myself, no flow #s) felpro Blues, a ported TPI base/plenum with stock runners and a set of Cobra 39s. Exhaust is shorty headers into 2.25 that merges into a single 3" exhaust.I'm running Megasquirt II for my ECU doing fuel and spark. Cam is a 91 Y-body/"good" F-body cam.
I've had issues with everything from using a Cold start injector TPI TB on a non cold start injector plenum to burnt plug wires to bad injectors. FP is ~43 PSI and pulls down to ~34 PSI at idle, which comes to 17-19" HG idle vacuum which my ECU confirms. All the plugs are even, and white now. As in the porcelian is brand new looking after 30-40 mins run and a few pulls around the block. I do not have a WB hooked up currently but the plugs tell a ton without even going that far.
Ultimately my question boils down to this:
At below 1500RPM and at the 30-35KPA cells I'm in the low-mid 60s for my VE. Does this even sound sane? It's about 15-20% more than the cells around it, I'm wondering if all the other issues I had are forcing me to add fuel because I wasn't burning it well before. Power drops off like a rock after I leave these cells (it won't go above 1700 or so) and it's really making me wonder if I have other issues still or if I just need to dump fuel into it till she's good.
Pic of the plug. The porcelian looks like that all the way back. I was initially leery it may be that I was running Autolites, but at the same time I guess not. I stuck NGKs in there and I like them better if only because they are about 1/8 shorter which is awesome since my headers are tight around my plugs in a couple spots.
Old Aug 23, 2013 | 12:40 PM
Ronny's Avatar
Re: Am I experiencing an issue?
Exhaust leak? Headers not sealing to head or collector to ext pipe connection?
allows fresh air in and drive BLM upward.
Old Aug 24, 2013 | 01:41 PM
Drac0nic's Avatar
Not running an O2 right now, just going off plug cuts. I was way way rich before, I didn't want to kill a perfectly good O2 sensor with dumb mistakes. Thinking it's seriously time for it to go back on.
Old Oct 2, 2013 | 12:12 AM
Drac0nic's Avatar
So, I found 10 degrees of timing I was missing due to a misconfiguration of my Megasquirt II. After pulling a ton of fuel from the middle of the map at WOT, things are running quite a bit better. As a dumb question, what are you folks typically doing for all in timing on a 305 at about 8.9:1 compression (L03 short block, 416 heads with a .034 gasket) with a stock 91 TPI "non peanut" cam? I'm still getting some dry fouling on the plugs at this point, so I'm wondering if adding a few more degrees would help clean things up some. It has a bit of a stumble like it could use the extra timing, adding or removing fuel doesn't seem to help it.
Old Oct 2, 2013 | 10:02 AM
Ronny's Avatar
I ran a stock LO3 timing table for quite some time. Worked fine just not as snappy as the blended LT1 iron and LT4 alum. If you have a stumble prob is fuel or mechanical/electrical. If you increase timing do plug checks and watch KC under load. some KC are not real ones.
Old Oct 9, 2013 | 11:33 PM
Drac0nic's Avatar
Ok, I started pulling a lot of fuel out in addition to the timing I have added. What is really messing with me is it has a verified 31degrees of advance at idle. Just makes little sense to me. Far as i can figure out i have too much fuel. I am thinking try to pull some timing and then pull fuel as well. Thoughts? Could the Cobra 39s be doing this?
Old Oct 10, 2013 | 02:42 PM
Ronny's Avatar
Seems like more than a stock vehicle would command. Make sure your initial SA is same in your .bin and at engine with plug disconnected.
I run 22dSA at idle. Works for me. I once had like 18 but idle is better at 22.
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Formula_88AE
Sep 3, 2015 01:47 PM
