ecm i got with a tune port setup
Old Dec 17, 2013 | 09:05 PM
rev.chuck's Avatar
01228062 did i get the wrong ecm?
Old Dec 17, 2013 | 10:09 PM
fbccars924's Avatar
Car: 94 D21
Engine: KA24E, 5spd
Transmission: 5spd
Axle/Gears: HG36, 3.60:1 LSD
Re: ecm i got with a tune port setup
Yes, Yes you did sir.
Lmao, I really don't know. But put it all together and see if she works.
Old Dec 17, 2013 | 11:24 PM
rev.chuck's Avatar
alton illinois?
<cottage hills
i googled the numbers they dont come up with any results to this engine and painless list's different part numbers for the ecm they want for their wiring harness.
Old Dec 18, 2013 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not enough information...
If your f-body is a '88 - '92 TBI that ECM will work. Although, it is a truck ECM. And, it needs to use the PROM that came with it, not the one from the OEM ECM.
For a '88 f-body with TBI, the correct ECM is 1228063
For a '89 - '92 f-body with TBI, the correct ECM is 1228746
If your f-body is outside of this (year or induction type), then the '8062 ECM won't work.
RBob.
Old Dec 18, 2013 | 08:16 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
$4E 1989 - 90 4.3L LB4, 2.8L LL2 S-10 wrong ecm
Old Dec 18, 2013 | 12:01 PM
fbccars924's Avatar
Car: 94 D21
Engine: KA24E, 5spd
Transmission: 5spd
It came with and intake and harness rev bought on a deal. So the ECM is for a 4.3 though?
Old Dec 18, 2013 | 12:22 PM
rev.chuck's Avatar
RBob.
its not going in an fbody i am putting it in my 62 oldsmobile eventually. just trying to get it all worked out first.
ok. what threw me off was painless ask's for certain part numbers for the ecm's and some of those part numbers match 4 cyl trucks, then you have replacement ecm's so forth so i was unsure.
im going to call painless and ask them if any ecm with that # will work with their harness
Old Dec 19, 2013 | 03:57 PM
Engine: Lb9
Transmission: M20
It sounds like you are going tpi maf, in that case you would need a 1227165 ecm that was used in s10's 87-91 with a 4 cylinder memcal. The 1227165 ecm if your looking at ebay or the junk yard may show any of these superseded numbers 16198259, 88999194 or 77-7165.
Old Dec 20, 2013 | 09:01 PM
rev.chuck's Avatar
ill probably just go after market harness and ecm make things easier
found a local place for both at 405 bucks and he's close enough if i have any issues i can just take a ride down to see him or have him tune it later
thanks for the replys
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Dec 6, 2015 11:25 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 13, 2015 07:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
