Problem with cranking.
Old Jan 4, 2014 | 05:12 AM
Amigaboy's Avatar
So my car had a butchered wire harness , and the car cranks without the transmission being in park. I would love to make it crank only in park. I have the switch on the gear shifter , and it works (checked it with the multimeter) so I need help , in which wire should I cut and reconnect via the gear shifter switch. The only wire that has power while cranking is a really thick one, And i think there should be something with less thickness to cut?
P.S. My car is a V6
P.S.S. Sorry for my bad english xD
Old Jan 4, 2014 | 09:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Problem with cranking.
The wire from the ignition switch to the starter solenoid is typically purple in color. It is also larger then most of the other wires in the interior.
RBob.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
