BS3-GEN3 Users.....
Old 03-13-2014, 02:31 PM
Royal_Z's Avatar
BS3-GEN3 Users.....
I have a question for all BS3 users.. I just purchased a used BS3 Gen3 ECM/ECU for my GTA.. Im building a stroker for it and decide to go with an aftermarket engine management system. Any hows, the BS3 does not come with the harness. So my questions are these;
One; Is it possible, or has any one modified the stock harness to be used with the BS3?
Two; do you use the stock original ecm/ecu to run anything at all? Or do you totally eliminate the stock computer out of the equation and run just strictly the BS3?
Thanks for any and all your help/suggestions..
Old 03-14-2014, 09:38 AM
Ronny's Avatar
Re: BS3-GEN3 Users.....
Cant you buy the harness from BS?
Below is in price list....
GEN3 Engine & Powertrain Management System - Wire Harnesses
Old 03-14-2014, 01:58 PM
Royal_Z's Avatar
I can, but the complete harness from BS3 is $700(plus)... so, i was just curious if any one had used the original harness off of the vehicle and converted it to be used with the BS3.. Also, im not sure if you try to send/post a link with your response, but i wasnt able to use it. thanks a lot for the response any how.. no one else has replied at all lol
Old 03-14-2014, 02:04 PM
Ronny's Avatar
How would you attach the interface on the BS3 ECU to stock GM harness? I am missing something? Stock GM female end of GM harness cannot just plug into BS3? Can it? Dont you "need" the female side interface that the BS3 harness has? If you had that you then could solder your stock harness to that pigtail.....
Old 03-14-2014, 02:24 PM
Royal_Z's Avatar
Well, that was my question, if any one has ever modified the stock harness to make it work.... but by the looks of it, no one has... so it looks like ill just end up ordering the complete harness from BS3.. lol
Old 03-17-2014, 09:37 AM
efiguy's Avatar
Hope you didn't pay a lot for it. They're great for drag cars, lots of datalogging, good traction control etc but don't drive all that well.
