swapped from a 700r4 to a T5
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I am finishing now on my 91. Do I need to get the chip redone?
Car: check
Engine: check
Transmission: check
Re: swapped from a 700r4 to a T5
Sometimes you do and sometimes you don't. The crank to run changes as three is a big difference in the mass on the TQ and the flywheel/clutch assembly. Also decel to idle can be troublesome. See how it is first.
RBob.
RBob.
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
