NEED HELP PLEASE !! ECM ECU prob?
Old Aug 31, 2014 | 03:37 PM
789roby789's Avatar
Car: 1986 Camaro Sport Coupe
Transmission: 700-R4
350 Carb. engine stock.
alright so im having trouble guys . my check engine light is on and i plug in the code reader and nothing it just stays light up no flashing or anything. i checked it and theirs power on my 10 amp fuse for the ecm and theirs power on the obd as well . i unplugged the 10 amp and the car started idling rough so im guessing my ecu is working properly.
although my carb isnt making the clicking noise when put in the on position. i ran 12v from the battery to the fuel mixture sensor that clicks and it only clicked once im not sure if thats the problem? what would trigger my light to stay on and not throw codes?? as well as my carb needs a rebuild could it be that my carb is just **** or is their a possible short somewhere?? i cecked all my emission hoses everything seems proper . im running out of ideas please help fam ! thanks
Old Sep 1, 2014 | 08:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: NEED HELP PLEASE !! ECM ECU prob?
Sounds like the ECM died.
RBob.
Old Sep 2, 2014 | 05:58 PM
789roby789's Avatar
You sure? Because when i took off the 10 amp fuse for the ecu my car started feeling crap. But once i put the 10 amp back it becomes a little better.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
KO1
16
Oct 15, 2015 05:00 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
