ECM\ALDL Connecting Problem
Old Aug 1, 2017 | 08:29 AM
Endschlag's Avatar
Hi
I have a Problem to connect my Custom ALDL Cable to the ecm of my 92 V6 Firebird.
I used TunerProRT4.14 and have the right ads File from my ecm 1227730.
Tunerpro canīt connect to the ecm and says connected fail.
The Cable ist tested on a other Car and is fine.
My question, i need more Files to connect TunerRT to the ecm? Bin or XDF?
Or is my ALDL connector wrong wired?
Greetings
Old Aug 1, 2017 | 12:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM\ALDL Connecting Problem
Have you tried other com ports ?
Old Aug 1, 2017 | 12:41 PM
Endschlag's Avatar
Yes no improvement, the ecm is new and work.
I have 3 ecm here the problem is by all.
Old Aug 1, 2017 | 01:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by Endschlag
Hi
Greetings
The ALDL connector is OK. The orange wire on the top right is pin M and is the 8192 ALDL data stream. The BLK/WHT in pin A is ground. See if you can blink codes. If so then the ground wire (pin A) is OK.
Be sure to use the $88 ADS file. Note that the $88 code chatters, so at times it can be difficult to connect.
RBob.
Old Aug 1, 2017 | 03:19 PM
Endschlag's Avatar
I have the $88 file
Old Aug 1, 2017 | 06:25 PM
Engine: Lb9
Transmission: M20
Have you tried using tp rt v5 ?
Old Aug 2, 2017 | 02:26 AM
Endschlag's Avatar
Hi
Of course is the same Problem.
Old Aug 11, 2017 | 03:47 PM
Endschlag's Avatar
I had a new Aldl Cable and he works.
I need help to translate the Data from TunerProRT.
The data was recording in stand by warm Engine.
I cant drive with the car on street, the idle is very bad and the engine dies by every light.
(TunerPro 4.14 is in the link)
https://drive.google.com/drive/folde...nltRWpYNXJQYzg
Greetings
