Ford Fuel Injector?
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Ford Fuel Injector?
Hi:
I took the fuel Injectors out of my GTA and they are FORD. Why somebody put FORD injectors in a GM GTA? I'm Lost.
Is their any benefit from this?
Should I swap back to a GM LIke Injectors?
What Injectors should I use if I decide to replace them?
David Reyes
David Reyes
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ford Fuel Injector?
Bosch 3s are from ford applications. The older blue and yellow tops have the same impedance as Bosch . If the engine was running well with them keep them. Southbay fuel injectors sells 22#hr injectors for your 350 tpi.
Car: Pontiac 89 GTA
It was not running good. I don't know if the injector are the cause but I sent them today to SouthBay to have them check.
Thanks for the info.
Engine: Lb9
Transmission: M20
They can be tuned for but unless you have a built 383 there isn’t a need for a injector that large. I bet you were running extremely rich. You might want to replace your o2 sensor too.
Engine: Lb9
Transmission: M20
I would put your money in replacing them. If you have them cleaned and flow tested that might run $10 -$15 or so each. Refurbished 22#her are $166. If you mention your a tgo member I think you get a 5-10% discount.
https://www.southbayfuelinjectors.co...0_TPi_i_1.html
Engine: Lb9
Transmission: M20
Car: Pontiac 89 GTA
OK I agree with you.
I already talk with South Bay and they are willing to do it any way I like.
If I'm replacing them what would you suggest I get? Remember that I don't min sending you my chip to be tune for them if your suggestion required it.
Engine: Lb9
Transmission: M20
The tuning would be a multiple tune process requiring you to datalog.
If you buy the equipment I would assist. You would need to get moates.net
G1 a few sst27sf512 eeproms a burn 2 and the extreme aldl with cable. This would cost you a few hundred dollars and your ecm is problematic to connect to just the nature of the 1227165 ecm.
I would look into there fuel rail o-ring kit and gasket kit if you can’t get these locally.
Engine: Lb9
Transmission: M20
Car: Pontiac 89 GTA
I'll probably want to sent you the ship anyway to make Shure nobody have work it before.
I found another computer I had save from other 1989 GTA so I can sent you the one for the current GTA so you can check that it still Stock.
Engine: Lb9
Transmission: M20
It would be the easiest for you. The Bosch 3s do have a audible clicking sound to them bye design or sound transfer to the intake manifold but they work well good value for the price.
Engine: Lb9
Transmission: M20
To modify it the silver sticker needs to come off so it can be ultraviolet erased. Or a piggy back adapter needs to be installed like the moates.net g1.
Car: check
Engine: check
Transmission: check
This thread is stupid. The is nothing wrong with Ford supplied Bosch injectors. Even though they are GEN 1, they work.
The issue is not the injectors but the tune. Get the tune set up for those injectors and the engine will run great.
And yes, the Ford/Bosch red tops are basically a 30 lb/hr injector. Unless tuned for they won't run worth damn.
RBob.
RBob.
Just because an injector is stamped Ford means absolutely nothing. They are made by bosch. Injectors are used in multiple applications. As long as they have the same flow rate and resistance most injectors can be used in any application.
Car: Pontiac 89 GTA
It was not my intention to make a stupid question. I didn't know that Buch made injectors for all cars and keep the Ford Logo.
Car: Pontiac 89 GTA
My current GTA Ship
Current GTA Chip Side View
Current GTA Inside View
Old GTA Ship
Old GTA Ship Inside View
Engine: Lb9
Transmission: M20
The apyu is stock for your 89 350 automatic 3.27 axle ratio.
The apyu looks to be all stock not modified.
There was a update but I don’t think there was any running issues with the apyu. The newer calibration is aujm.
The Hypertech is a aftermarket but would not be programmed to account for the 30#hr injectors.
https://www.summitracing.com/parts/HYP-128922/
Car: Pontiac 89 GTA
For the record, my 89 Iroc, 5.7L with 2.77 ran GREAT, and even passed NC emissions YEARS ago with 24# Bosch/Ford injectors and the Hypertech chip.
Agree that Bosch/Ford makes no difference.
Agree that flow rate and matching tune matters.
Hypertech is basically stock. -at least for the sake of this convo
All things being equal, I'd get 22/24/stock flow injectors BEFORE tuning a stock engine to run on 30 pound injectors. -although I DO agree it would run just fine if you did. -That being said, if tuning is something you're interested in, then sure, might as well keep the 30 pounders and jump in. ....but if the intent to to simply keep a stock engine running right.....I'd swap injectors. The more things you keep stock the better, for you or anyone else who may have this car.
Car: Pontiac 89 GTA
when I get my 22# injectors will start with the OLD GTA Stock.
Any thing you advice I replace before trying the injectors beside the O2 Sensor?
Engine: Lb9
Transmission: M20
Nothing else I can think of. Should run much better with the correct injectors.
Engine: Lb9
Transmission: M20
Slow89Iroc-Z
Feb 4, 2002 02:47 PM
Slow89Iroc-Z
Feb 4, 2002 11:45 AM
