Prom Swap
Prom Swap
Service #16198445. Taking the Prom from my 87' GTA and using it in this ECM. The Prom # was DELCO AUXF 3766 In this 87' Corvette ECM. The GTA Prom # isDELCO ABWT 8674. Seems I counted 31 not 32 pins in the Corvette ECM. Could this be a problem? Thanks for your time.
Car: check
Engine: check
Transmission: check
Re: Prom Swap
Not sure what pins you are counting, but a '8445 ECM ('7165), is a '8445 ECM. The application it was used in doesn't matter.
Note that the information I have shows AUXF being for a small truck with a TBI 4-banger.
RBob.
RBob.
Re: Prom Swap
Counting the Pins that the Prom attaches too. Swapped it over and hoping to just plug the ECM back in and all will be good for a test drive. Anything else that I need to know? Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Prom Swap
Disconnect your battery before swapping out your original memcal.
Transmission: 5-speed/T-5
Re: Prom Swap
If you counted the pins on the PROM itself and came up with 31, you miscounted. There will be an even number of pins.
Re: Prom Swap
Ok.Swapped the Prom and flashed her up. Seemed to run alot smoother for a few minutes,till nice and warm .Shut it off and won't fire again. Have to leave for a while before it will fire again. Will run ,but quits after a few seconds now. Have not checked the spark yet. Any Ideas?
Engine: Lb9
Transmission: M20
Re: Prom Swap
Check fuel pressure as well as spark .
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
