Odd A/C request behaviour
Old Jun 1, 2018 | 10:30 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
I'm installing a SD TPI unit, AXXB memcal. (Also does the same with AUJP memcal installed) I only have a handheld scanner. When I turn the A/C on, the primary fan does not come on and the scanner reads A/C Request:OFF. The idle does not speed up either when the A/C is on, compressor clutch is engaged.
Did some tests and
-Primary fan will turn on when ALDL A and B are jumped.
-Primary fan will turn on when engine reaches approx 228°F
I measured voltage at C2 connector - C9 green wire at the ECM. Is shows approx 12v when the A/C controls are turned on.
Today I purchased another 7730 ECM. It exhibits the same as above with both AXXB and AUJP proms installed. I tried BAWX 6 cylinder chip and with that prom in and the ignition set to run, my scanner shows the the A/C request gets activated as soon at I turn the a/c controls on. So it can't be anything with the wiring since it uses the same C9 input wire. What could be causing this?
I guess to sum up: tried with 2 ECMS, only BAWX prom will detect A/C requested, AXXB and AUJP will not. Kind of running out of things to try. Thanks
eddie jr
Nov 22, 2015 08:47 AM
perZ
May 25, 2015 11:58 PM
NiG
Nov 30, 2014 11:23 AM
devilfish
25
Jun 9, 2004 04:25 PM
86FyrBrd
Feb 14, 2003 12:05 PM
