Ms3 Pro ultimate
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Ms3 Pro ultimate
Anyone using the ms3 pro ultimate? Looking into it for a turbo setup with a 4l80e. Because it has trans control built in. Pro/cons?
Transmission: 5-speed/T-5
Re: Ms3 Pro ultimate
It doesn't have trans control built in, you need a Microsquirt (connected through CANBUS) to control a 4L80E.
Car: 92 rs
Transmission: 4L80E
Car: 92 rs
Transmission: 4L80E
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
There have been alot of issues on ms3 pro’s last year or two now. Injector drivers were failing and melting cars down when fuel delivery failed. I would go holley
Car: 92 rs
Transmission: 4L80E
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The Holley software is nice and easy to use, but doesn't have all of the features of the MS3 Pro, but not everyone needs all those features.
The MS3Pro module is like $800 and can fit inside a factory PCM case for a plug-n-play combo. It's all SMT electronics so it's more reliable than the v3.x based PCB's.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I really like it, but it's flexibility sometimes causes confusion as it's a complex system. Most of the support forums expect you to be an advanced EFI user, so sometimes beginners don't get the level of help they need to be successful.
If you can be specific about the exact requirements you need or want we could probably give you some pros and cons. I.e sequential vs batch fire, what triggering system you use, etc.
-- Joe
I bought this for a turbo 4 cylinder- but haven't used it yet. He has a V8 version with cnp and knock.
https://controls.is/shop/ecu/lpc4
Car: 89 Iroc-z
Transmission: TH400
I think it was like 5 units out of a few thousand, but still any number is unacceptable.
-- Joe
-- Joe
98% of people dont need anymore than what holley hp gives you
most guys on here dont need anymore than stock 730 ecm tbh
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
But yeah, you are right, most people on here don't need any more than a stock '730. But in regards to performance, this place is dead and stuck in the ages. Most of my exposure to high tech builds is on facebook groups now.
Even the turbo forums are boring now.
-- Joe
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
So the choice was between a $2,500-3,000 setup by Holley or an $800-1000 setup that has (or at least can have the arguable ability) the same features and you went with the $3000 setup? Why?
Car: 92 rs
Transmission: 4L80E
MS3Pro-$1200-$1400 depending on which model I chose.
Wiring harness-$299 plus connectors it’s a flying lead.
Micro squirt 4l80e trans controller and wiring $500 (been out of stock for months)
So there’s and easy $2200 after connectors for wiring harness
Holley dominator efi $1700
Wiring harness-$350 plug and play
4l80e harness $177 dominator controls it also
So there’s roughly $2227
Not much difference and the Holley unit is all plug and play. Plus
Who knows when a micro squirt setup will come back in stock.
Car: 1991 Z28 Vert
I think your figures are a little off. If money isn't an issue for you or the Holley has some feature, convenience or warranty that MS didn't then that's fine but otherwise you might take a look again.
DIY AutoTune has the MS3Pro with the harness included for $1500 normally and they will frequently run 10% off making it $1350. I've seen it at 20% off on Black Friday I thought which would make it $1200. I found the MicroSquirt 4L80E controller at two websites that didn't say it was out of stock and allowed me to add it to the cart and go to the payment screen at checkout. Grab a blutooth connector (I can't recall but I know mine wasn't more than $50) and you can mate it to any android phone or tablet.
MS3 Pro $1500 at least $1200
Controller $500
Blutooth controller $50
Total roughly $1750-2050
The Dominator EFI $1700
Wiring harness $350
4L80E harness $177
Holley LCD dash $840
Total roughly $3067
Controller $500
Wiring harness $350
4L80E harness $177
Total roughly $3067
Car: 92 rs
Transmission: 4L80E
Why didn’t you include the lcd for the ms pro at $995 from diyautotune? That brings it closer again. But the screen isn’t a requirement on either setup
as far as the microsquirt I hadn’t looked anyplace else other than diyautotune. Because I didn’t like having to run a separate unit to control the trans.
Car: 1991 Z28 Vert
I figured it had to be something like that. I know some guys that also only buy big name parts because they are building a show car and are looking to win big awards, didn't know if it was something like that either.
Car: 92 rs
Transmission: 4L80E
Screen looks nice. But id have to buy a tablet. Lol. Never had s use for one. Ill admit also ive never messed with tuning an aftermarket efi.. and the software looks more user friendly and straight forward on the holley.
Car: 1991 Z28 Vert
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think it's time for MS4. The trans controller needs to be built into the main ECU. This is probably what hangs up a lot of people.
That, and when they realize they don't know how to tune they can just drop it off at a Holley shop.
I'm still running MS2 though and the car runs perfect.
It's my stock Corvette that keeps having PCM issues. GM electronics are junk lol.
-- Joe
-- Joe
Car: 1991 Z28 Vert
I'd be interested in the ability to add the feature to a new ecm along with a VSS buffer OR an internal GPS feature. I think making the Transmission controller with harness standard would drive up the price by $300? maybe less? If you had a manual tranny it's something you wouldn't need either and that's been one of the big features of the MS Platform, being able to buy only what you require. Bare bones fuel only MS1 or shoot-the-moon MS3 Pro with a trans controller.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
rsrmoore
Apr 4, 2015 07:05 PM
