86 Camaro 6.0/twins/ms3 Pro build thread
Old Oct 7, 2017 | 07:03 PM
Big, White & Sl's Avatar
Car: 86 Camaro
Engine: 355
Transmission: Powerglide w/brake
Axle/Gears: Currie 9" w/4.56
I've got a build thread in a couple of other places but I've neglected to put one here. Here's the plan, going to convert my racecar to a street strip car. I have most of the big stuff already, but it'll be a slow process as I work by myself.
6.0 LS w/callies rods and weisco pistons
LS3 heads
twin 72/68 Rev9 ebay specials
twin A/W I/C's (same setup as Orr's)
MS3 Pro Evo
E85
210lb bosch inj
p/g w/brake
9"
Old Oct 7, 2017 | 07:05 PM
Car: 86 Camaro
Engine: 355
Re: 86 Camaro 6.0/twins/ms3 Pro build thread
Took the old high compression 355 out and sold it
Old Oct 7, 2017 | 07:06 PM
Car: 86 Camaro
Engine: 355
PA Racing k member and a arms installed
Old Oct 7, 2017 | 07:07 PM
Car: 86 Camaro
Engine: 355
got the nose off for all the piping. Next step is strut mounts and coilovers.
Old Oct 7, 2017 | 07:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I haven't followed MS as closely as I used to. I am running the MS3 Extra, whats the MS3 EVO about?
Old Oct 8, 2017 | 08:56 AM
Car: 86 Camaro
Engine: 355
MS3 Pro is like regular MS3 on steroids. Has all kinds of features. This is off the diyautotune website:
MS3Pro EVO Configurable Inputs/ Outputs:
10 Hi impedance injector outputs
8 logic level spark outputs
3 PWM outputs
2 digital outputs
7 analog inputs plus built-in MAP, Baro, and internal ECU temp sensor
3 high current digital/pwm outputs
3 digital frequency inputs
4 variable reluctor conditioned inputs
MS3Pro EVO Features:
VE based tuning
Speed Density, Alpha-N, MAF based tuning & blended algorithms
Up to 12 sequential saturated fuel injector outputs
Up to 12 cylinder sequential support
Any unused injector outputs can be used as high current digital or PWM outputs
Up to 8 sequential logic level ignition outputs
2D or 3D Table Views
The tuner can toggle between 2D or 3D table views with a single click
Individual cylinder fuel & spark trim tables
Table Switching
VVT Control (4 channels)
Generic Wheel Decoder allows for support of nearly any standard trigger/aftermarket trigger pattern. 60-2, 36-1, 8-1, 4-1, pretty much anything!
Supports 50+ specialty OEM and aftermarket ignition systems using factory cam/crank wheels and sensors.
Support for oddfire and evenfire engines
Capable of controlling evenfire, oddfire, piston, rotary, and even radial engines
Fuel Only Mode
Disables ignition output features for control of fuel injection only
Internal SDCard high-speed data logging
Traction Control – Multiple Strategies
E85 flex fuel sensor input
Compatible with YOUR wideband O2 controller.
Long Term Fuel Trim
OE Style automatic fuel trim to allow for changes in engine over time
High Power Time Enrichment
Allows for richer mixture after extended time in high power
Helps control cylinder and piston temperatures
Fully user configurable
Multiple Acceleration Enrichment Strategies
Staged Injection Control
Seamless transition to 2nd stage injectors for high power applications
Multiple user configurable strategies
Nitrous control strategies
Three-step rev limiter with flat shift
Trans Brake and Bump Box Control
No need for a separate box!
User configurable settings and reactions
Advanced Launch Control strategies
Digital switch based arming
Wheel speed based launch arming for rolling starts
Configurable timing retard after launch
Pit Lane Limiter
Speed limiter for pit lane, reduces engine power by spark retard/cut or fuel cut
Can limit based on VSS or RPM if no VSS input is available
Rally style turbo anti-lag with rotational idle
Allows cyclic fuel and spark cut
Controls idle valve and configurable outputs for external fuel or air supply
Boost Control – Multiple open & closed loop strategies
Sequential shift spark cut
Configurable spark and fuel cut during shift
Solenoid output control for air shifter/drag application
Automatic shift point mode
Configurable per gear delay
Idle Control – Multiple open & closed loop strategies
Water and Methanol Injection
Fuel Pump Control
Intelligent Knock Detection and Response – 2 channels
Multiple Engine Protection and fault mode strategies
Generous spare I/O for any standard/custom I/O needs
Spare analog inputs for external sensors
Supports standard automotive temperature or pressure sensors
Air Conditioner Control with feed-forward Idle-Up
Proactively increases idle vale duty cycle (PWM valves) or number of steps (stepper valves) before activating A/C compressor
Automatic compressor shutoff at programmable throttle position or RPM thresholds
Automatic cooling fan activation with A/C, user configurable
Cooling Fan Control
Programmable fan on and off activation points
Can be configured to run fan with engine running only, or when engine is running and not running
Feed-forward idle up for use with large, high demand fans
Configurable fan deactivation based on TPS or VSS
Alternator Field Control/Voltage Regulation
Multiple open and closed loop strategies
Configurable voltage and temperature monitoring
Separate target voltages for afterstart, normal operation, over run, and WOT
Warning lamp output if voltage is above or below target
Comprehensive Test Modes
Test all outputs for proper functionality and verify wiring before starting the engine
Controls all fuel injector outputs, ignition outputs, idle valve, and general purpose outputs
Outputs can be tested for on & off or PWM pulse functionality
Injector and spark disable mode, allows checking for suspected problematic cylinder by electronically preventing combustion event
CAN Support for I/O expansion – virtually limitless I/O capability!
CAN Support for 3rd party dash devices
Android Compatible
Self Calibration
Fully Enabled
Compact, Efficient & Robust Design
Redundant signal ground wiring
Dual external 5V ref supplies, individually fused
No Dark Current!
Field Upgradeable Firmware – enable newly added features with a simple firmware update!
The EVO is the middle product. The ultimate is the top and the original MS3 Pro is the bottom. The EVO is an original MS3 Pro with some of the ultimate features added.
https://www.diyautotune.com/product/...gement-system/
Here's a link
Old Oct 10, 2017 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Nice, looking forward to this. It should be stout
Old Oct 10, 2017 | 02:35 PM
Car: 86 Camaro
Engine: 355
I hope so. I'm shooting for 1000 at the crank and mid to low 5's in the 1/8. I'm stealing the I/C setup idea from you.
Old Oct 10, 2017 | 02:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You'll easily make that power. The intercoolers work well! You'll like them. Just get a good sized tank and use couple bags of ice and alittle prechilling time
Old Oct 10, 2017 | 03:48 PM
Car: 86 Camaro
Engine: 355
That's the plan. I have a 5 or 6 gal tank with the pump already. Just gotta figure out where I wanna put it
Old Oct 19, 2017 | 12:16 AM
Car: 86 Camaro
Engine: 355
Coilovers on
Old Oct 19, 2017 | 04:35 PM
DIGGLER's Avatar
random question- how many inches of "droop" does the coilover setup have from the resting on the ground position to jacked up with tires off the ground?
Old Oct 20, 2017 | 02:14 AM
Car: 86 Camaro
Engine: 355
I don't know yet. I haven't had it on the ground yet since I put them on. It'll probably vary depending on the spring rate you use. IIRC mine are 175lb
Old Oct 20, 2017 | 07:33 AM
DIGGLER's Avatar
i wasnt thinking when i asked that. i believe with these cars it should pretty much be the same amount of travel when going to coilovers compared to the stock setup.
Old Oct 21, 2017 | 01:53 AM
Car: 86 Camaro
Engine: 355
I would guess so since the arms are stock length and it uses the same struts.
Old Oct 25, 2017 | 01:39 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Good build, subscribed...
Was always a sucker for a well built notchback. What are the specs on that Fox Body that is hidden in the back of the first picture...
- Rob
Old Oct 25, 2017 | 08:54 PM
Car: 86 Camaro
Engine: 355
That fox was my daily that I gave to my son for his first car. It's a 79 with an 85-86 nose and rear bumper. 302 with cam, intake, carb, shorty headers, catless h pipe, and magnaflows with turndowns. It's been converted to an AOD and since I gave it to him we added the welds and an 8.8 with 4.10's. It's a manual window car. Nice interior but needs paint and a new top
Old Oct 26, 2017 | 09:16 PM
Originally Posted by Big, White & Sl
That fox was my daily that I gave to my son for his first car. It's a 79 with an 85-86 nose and rear bumper. 302 with cam, intake, carb, shorty headers, catless h pipe, and magnaflows with turndowns. It's been converted to an AOD and since I gave it to him we added the welds and an 8.8 with 4.10's. It's a manual window car. Nice interior but needs paint and a new top...
A new top? It's a vert? Hard to tell from the pic, but either way it sounded like a fun ride... and one hell of a first car for a kid. Meanwhile I say this as I am watching Stephen King's "Christine" on cable, hopefully he doesn't become that obsessed with it lol. The Camaro build sounds very well thought through, looking forward to the updates.
Old Nov 2, 2017 | 06:19 PM
Car: 86 Camaro
Engine: 355
It's a vinyl top car. I don't think he'll get obsessed. Hell, he doesn't even seem really interested in it. Every time i see it it's filthy.
Old Nov 6, 2017 | 10:59 PM
89FormulaLS's Avatar
I ordered a couple Hall effect sensors for my ms3 pro ultimate today. Going to try and pick up brake Rotor vanes for traction control, If your going to run the same setup I will post up how I end up mounting them. Running off digital io 2 and 3 on the center harness I think with sensor grounds.
Old Nov 7, 2017 | 05:06 PM
Car: 86 Camaro
Engine: 355
Go ahead and post them up. The EVO doesn't have the center harness, but at some point I'm gonna want to run traction control and it'd be nice to see some options
Old Nov 18, 2017 | 05:42 PM
Car: 86 Camaro
Engine: 355
Engine compartment painted with POR15
Old Apr 7, 2018 | 05:13 AM
Car: 86 Camaro
Engine: 355
Time for some updates. Progress has been slow because of other stuff going on.
First, I got the Motion Raceworks soft steamline setup on
Remote coil mounts assembled
Bought an Autokraft pan and added fittings for the turbo oil drains
Did the Astro van steering shaft conversion
Got the pan on and all buttoned up
Oh and I shaved a set of valve covers and I'm gonna paint them tomorrow. I'm using 2 of the oil filler ones because I'm gonna run the billet oil filler caps that have the -10 fitting coming out for a breather setup. The ones in the pics are just the extras
I've done all the clearance mods to get the CSR trans shield to fit on my PG, just waiting on some 90's for the trans cooler lines and a new trans mount and that will be ready to go. Hopefully next weekend I can set the motor and trans in. Then the fun begins. LOL
Old May 16, 2018 | 05:30 PM
Car: 86 Camaro
Engine: 355
Got the engine in a couple of weeks ago. Trans is in too, somewhat, but now I have a problem. I'm running a powerglide with a CSR trans shield and any of you who are familiar with them know that they mount using the bellhousing bolts. They have a little aluminium spacer at each hole and a steel plate that goes across. Here's the problem, that stuff means using a longer bolt and moves the bolt holes closer to the firewall and there's no way those bolts are going in(top 4 bolts). Looks like I'm going to have to cut some access holes in the floor and make some removable panels to get to the bolts. I'm wishing now that I'd just bucked up and bought a trans with an aftermarket case.
Old May 31, 2018 | 02:27 AM
Car: 86 Camaro
Engine: 355
Headers and valve covers(shaved stock ones) on. Working on alternator mount. It's a pain. Had to notch the block and now i have to replace a bad helicoil
Old May 31, 2018 | 01:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Looks really good
Old May 31, 2018 | 03:04 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Did you shave the stock valve covers yourself? How hard was that?
And where will you be installing the remote mount coils?
Old May 31, 2018 | 07:53 PM
Car: 86 Camaro
Engine: 355
I did shave them myself. It was a good amount of work. Used a cutoff wheel then a small grinder. Filled the leftover holes with epoxy. I'm either gonna put the coils in the cowl area or mount them on the frame rails so far
