'88 IROC-Z ECM
Old Aug 24, 2018 | 07:28 PM
jbates346's Avatar
'88 IROC-Z ECM
I've tried to do a little research as far as the ECM location for my '88 IROC-Z. So far from what i've read, it's under the passenger side dash next to the heater box. I just wanted to see if this was correct? For whatever reason my auto shop couldn't find it anywhere. Thanks for any help.
Old Aug 24, 2018 | 07:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: '88 IROC-Z ECM
Your correct on its location. The ecm and it’s bracket drop down from under the dash. It’s basically under the dash speaker.
Old Aug 24, 2018 | 07:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: '88 IROC-Z ECM
Yes, up under the dash on the passenger side. Should be a decent size aluminum box. But could also be a black painted box if a re-man.
Has two harness connectors. One is 12 x 2 rows, the other 16 x 2 rows.
RBob.
Old Aug 25, 2018 | 08:19 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: '88 IROC-Z ECM
Time to find another auto shop.
speedmachine
Aug 14, 2007 07:28 AM
95Z28A4
May 8, 2001 04:52 PM
steve8586iroc
Jan 31, 2001 05:40 PM
mirage2991
Dec 7, 2000 09:04 AM
