Tpi 305 fuel Rail presure gauge
Re: Tpi 305 fuel Rail presure gauge
Don't know that there are any. I know Accel used to make one but it was known to leak. ....I bought a gauge off ebay for about 20 bucks, and went to the hardware store to find some fittings. Been using it for several years without issue.
edit** ....wow so I stand corrected. LOTS available! ....a quick search of TPI fuel pressure gauge revealed LOTS of options. Did you actually look?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: check
Engine: check
Transmission: check
Don't. It is of very little use. Get a fuel pressure gauge that has a hose to connect to to the fuel pressure port (-4 or JIC). A liquid filled gauge is best, as long as it isn't left under the hood.
RBob.
RBob.
R3500
Jun 21, 2008 07:10 AM
camaro6spd
Oct 18, 2001 10:49 AM
michael
Jun 24, 2001 08:16 AM
