Use knock sensor for boost retard control
So I'm just getting into doing a low boost....7psi or lower vortec 5.7 in a 1999 tahoe. I was wondering if I could somehow use the knock sensor input wired to a Hobbs style switch that would come on at 1 psi, and ground the pressure switch. When the hobbs switch feels boost it will ground the knock sensor pcm wire and trigger the knock retard .
In theory couldnt I then adjust the knock retard tables to suit my needs to use the knock retard table as a boost retard? Or will this not work like I am thinking?
Pupkin
Jun 2, 2019 03:14 PM
Firebat
Jan 12, 2012 08:02 AM
torqueaddict
Aug 29, 2009 10:15 AM
