Fast Ez Efi 2.0 + torque converter lockup
Old Feb 25, 2020 | 09:24 PM
IZ4U2NV's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7tpi
Hey guys new to the fourm have been reading lots in here the last 2 years but never made an account but I need some information that I cant seem to find anywhere.
I'm going to buy the Fast EZ-efi 2.0 for my car, I've done lots of research on this and for my situation I feel it's my best bet. My only problem is I want to take the stock ecu right out of the car but I'm reading about torque converter lock up and if I do remove the ecu then lock up will no longer work? Also heard it only locks up in OD, if that's the case can I just forget about it? Really not sure how it works or what I need to do to make sure it's working properly if you have any information that can point me in the right direction that would be appreciated
1989 iroc
5.7tpi
700r4
Old Feb 26, 2020 | 10:46 AM
TA-hawks-3rdgen's Avatar
Car: 1982 trans am
Transmission: th350
Re: Fast Ez Efi 2.0 + torque converter lockup
If the computer doesn't have lock up potential you can just wire in a manual switch and toggle it
Old Feb 26, 2020 | 10:54 AM
IZ4U2NV's Avatar
Engine: 5.7tpi
When would I lock it up and unlock it?
Old Feb 28, 2020 | 12:05 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
when cruising in 4th gear
Old Mar 1, 2020 | 10:53 AM
86L69's Avatar
Who want to bother with a toggle? Not all of us will highway cruise for 100 miles at a clip. What is the best modern EFI system that maintains torque converter lockup and EGR function? Without these functions might as well go carb.
stevek
May 1, 2013 10:11 PM
n1ffer
Oct 10, 2010 08:42 PM
Jason E
Jun 13, 2010 10:08 AM
luke4907
May 17, 2004 12:52 AM
Chris's 85z
Apr 25, 2003 06:51 PM
