What chip?
Old Sep 15, 2020 | 10:16 PM
CamaroJimbo's Avatar
Car: 2015 Chevy Tahoe LTZ, 1985 Camaro
Engine: 350 4BBL
Axle/Gears: No idea
What chip?
I am lost and hope someone can point me the way out of this PROM craziness. I swapped a 350 into my 1985 Sport Coupe and learned I also need to change the ESC module and the knock sensor to those for a 350. I have ordered them and they are on the way. Where I am lost is regards to what PROM I need to use for my application. My Camaro ECM has a number 1226865 on it, which does not match the one most discussed here in the forum and my car has a 4BBL computer controlled carburetor. What chip is needed to maximize the power of the new 350?
I read somewhere about a chip for a 91 Caprice cop car, but I am pretty sure they are TBI. Would that particular chip work for my application even though I have a carburetor? I have been advised that I could continue to use the ECM as is but the engine would not be optimal, which is kind of the point of the bigger motor. Mods include Edelbrock Performer intake, headers, 3" exhaust, flow master cat and muffler, so nothing exotic. Any help would be much appreciated. I just need to know what I have to order to make this car growl.
All cleaned up and ready to run!
Thanks in advance! (a little timing joke.... )
Old Sep 15, 2020 | 10:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What chip?
Another mask won’t work Duce as 91 caprice. Will be better off going to efi or non ccc.
Old Sep 16, 2020 | 11:49 AM
GeneralDisorder's Avatar
Re: What chip?
No one does chips for the CC carbs and you are correct that the TBI chips are completely incompatible - different computer entirely.
The "chip" on the CC carbs only affects idle and closed loop operation - which is cruise conditions, etc. It has little effect on WOT operation. It's still a carb and subject to the normal q-jet jetting and rod calibrations.
GD
Old Sep 27, 2020 | 10:19 PM
Engine: 350 4BBL
Axle/Gears: No idea
Re: What chip?
Outstanding. One less thing to worry about... a good tune and we will be good to go. Thanks GD!
CamaroJimbo
Sep 28, 2020 09:40 PM
C305
Aug 19, 2012 08:42 AM
samiam91RS
Apr 4, 2008 09:29 AM
CamanoWagon
Dec 21, 2005 06:18 AM
jayk2k3
Jun 29, 2005 05:27 PM
