1990 ecu vs 1988 ecu?
Old Oct 5, 2020 | 11:06 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
Is the only difference between the 2 the use of MAP over MAF?
Asking because my 88 GTA has the MAP sensor and no MAF and I wanted to get an EBL P4 assembled with the 7730 ecu (90-92 ecu).
Old Oct 5, 2020 | 11:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1990 ecu vs 1988 ecu?
If tpi $32B is maf not map, the ebl p4 1227730 is map. Can repin your ecm connector and retire the mag connection to map.
88 tbi is map but look at the flash 2.
Old Oct 6, 2020 | 05:27 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Also the P4 with the '730 case uses a different mount than the '165 / flashII does. The biggest difference better the operations of the 2 is the P4 allows more aux inputs than the Flash II if I remember right it's 8 vs 4.
Old Oct 6, 2020 | 05:48 PM
msammy93's Avatar
Engine: 383 TPI
Yeah I contacted the company who produces the EBL and was told regardless of whether I have a map or not I would have to use the flash II unless I want to repin all the harnesses since in 1990 they went to 3 plug versus the older 2 plug style. This weekend or next weekend I'll be pulling the computer out to check whether it's a 2 plug or not before I order the EBL flash II as the previous owner who made all these mods died and left behind no notes or paperwork for anything
TheExaminer
Dec 13, 2015 11:25 AM
Siggy
May 25, 2005 04:01 AM
89 Iroc Z
Aug 1, 2002 04:33 PM
88TPI406GTA
Nov 20, 2001 11:06 PM
