305 to 350 PROM issues
Old Apr 12, 2021 | 03:54 PM
Jjw2419's Avatar
Hello all hopefully someone can help me solve this problem, my car is running awful. Just had a swap from 305 to 350 zz4 motor and used the original TPI system except added high flow injectors and had a new corvette prom chip installed. Now the car surges at idle and had to bump the idle up to 1,000 RPM to
lessen the surge and ensure it won’t stall. The car will tour the parking lot on its own because the idle is so high and the surging is annoying to say the least. Also it sometimes bogs and hesitates when I hit the gas. I ordered another 1985 prom chip of eBay to see if that might help, but it won’t be here for a few weeks. Any help would be greatly appreciated, the car is not fun to drive.
Old Apr 12, 2021 | 03:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 to 350 PROM issues
Two versions of hlh if that’s the bcc your using 3200 is the latest.
better to custom tune and datalog to refine the tune win aldl connects to the 870 ecm. Better to upgrade to the 165 ecm
Old Apr 12, 2021 | 04:03 PM
Jjw2419's Avatar
Thanks! I have heard the 1985 Ecm is the worst but your suggestions should help.
Old Apr 12, 2021 | 04:26 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
1985 Corvettes had 24 lb injectors. What size did you install?
Old Apr 14, 2021 | 07:45 AM
Jjw2419's Avatar
I installed 30 lb fuel injectors as hypertech indicated I needed for their chip. When calling them they indicated the chip is for a stock engine so any modifications may effect it. The replacement 350 zz4 only really has a modified cam vs the regular stock motors.
spitfireIX
Jun 13, 2012 01:16 AM
Chevy86 IROC-Z
May 20, 2010 06:43 PM
Chevy86 IROC-Z
May 14, 2010 06:11 PM
TransAmSteve
Dec 1, 2009 06:40 PM
fbird92
Apr 9, 2006 11:13 AM
