no crank till you pull the fuse out
Hi all, new to this site and could use some help.
89 TPI 305 wont crank over with the key ...starter relay clicks and no fuel pump.
If I just pull the ECM fuse out near the battery it cranks over and this is confusing...why with the fuse pulled will she crank?
If the fuse is installed and I hold the realy on it will also crank over
The fuel pump will run sometimes... Vats good and it was running fine as it already has a new fuel pump, injectors, fuel regulator, complete distributor and coil...new battery alternator and starter as well as a complete tuneup...there were all part of the refresher I gave her.
have a shop manual so I can follow the wiring but what to check first?
Thank you
Thank you
Carnage87
Jan 13, 2021 12:03 PM
