DFI timing won't go below 10 degrees
Old Jan 17, 2002 | 10:19 PM
DavidR's Avatar
I followed the directions in the Calmap manual to set the timing. Tried to put it at 8 deg but it goes down to 10 deg after warm up (on the view screen) and stays there. I didn't know what to do next so I set the dist so the mark hits at 10 deg.
The entire timing file is set to 8 deg and the idle spark is zeroed.
Anybody got any guesses as to why?
Old Jan 19, 2002 | 10:14 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I thought I answered this, but aparently it didn't go thru. Anyhow...
You need to get the idle up over 1200 or 1500RPM for the table to take full control. Otherwise I believe the ESC module is adding timing.
Old Jan 21, 2002 | 12:00 PM
DavidR's Avatar
Thanks RCR, you probably did address that issue already but I didn't see it. I should've done a search first I guess.
dr
Old Jan 22, 2002 | 08:13 AM
RCR's Avatar
RCR
No complaint to you Dave. I thought I answered your post previously, but when I checked it later, my answer wasn't there.
Old Jan 22, 2002 | 07:48 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I thought if you zero'ed idlespark you didn't need to raise the RPM to get the timing?
Old Jan 25, 2002 | 07:37 AM
RCR's Avatar
RCR
I think I tried that and it didn't make a difference. I think I read somewhere in one of the manuals I downloaded that you need to bring the RPM up. If I sound a little unclear, I am. I was thinking, can the spark advance plug be disconnected like on the stock ECM to do the timing? (The connector by the pass. side shock tower).
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
justin57
Aug 20, 2015 07:05 PM
bamaboy0323
Aug 15, 2015 07:20 AM
marcusaw
Aug 10, 2015 08:13 AM
