bypass EST
Old Jan 17, 2002 | 10:19 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
bypass EST
i've installed the holley pro strip annililator ignition on my '86 t/a 5.7l TPI. took the ignition module out. so the EST code is now tripped. the four wire connector has two not being used. they are an input and out put reference to the computer. what do i need to do to get the computer to think that it is working? i've tried to loop the wires and no go. i've tried looping the distributor pulse to the input. no go. i've tried pulse wire to the output wire. no go. the fourth wire is to the condensor. at least i can make my own timing curve now via the holley.
$750 L98
Feb 1, 2025 02:25 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
L98GTA87
Oct 19, 2015 10:43 PM
Formula8r89
Sep 22, 2015 04:24 PM
pacoelrapido
Sep 11, 2015 02:41 PM
