Can't find ECM, please help
Old May 25, 2022 | 06:49 PM
OG 87iroc-z's Avatar
I have an 87 irocz and can't find a ECM or E-prom anywhere. ECM part number is 19367537
E-prom part numbers is 16071137. Any help is greatly appreciated!!! I have tried several different outlets with no luck. Thanks in advance!!!
The car is a 305 tpi 5spd. 3.45 gear ratio also
Old May 25, 2022 | 07:08 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Can't find ECM, please help
Rockauto has the ECM, you could probably order a prom burned the way you like from Tuned Performance.
Old May 25, 2022 | 07:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
ACYD can be substituted with other broadcast codes . They usually don’t go bad . If you have a code 41 or 51 might replace the 1227165 ecm first.
Old May 26, 2022 | 03:14 AM
One thing I forgot to mention was the reason I need to replace them is the ECM or E-prom shorted out and almost caught fire. The car was in my friends hanger and the battery went dead so he put it on the 200 amp jump start and forgot about it. I would think a fuse would have popped but when I showed up to move the car for him I turned the key on and the ECM immediately started smoking.
Old May 26, 2022 | 09:43 AM
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/17529477124...mis&media=COPY
the aanm can be reprogrammed to work, or I have memcals close just not that code
Old Jun 3, 2022 | 09:00 PM
Engine: Lb9
Transmission: M20
Just sent you a email
9manastacio
Jul 25, 2010 04:06 AM
FireChicken2.8
May 16, 2009 08:52 AM
Blue1989RS
Nov 6, 2003 01:29 PM
dimented24x7
Aug 17, 2003 10:29 PM
