Surge at Cruise
Old Jun 23, 2022 | 04:02 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Surge at Cruise
Experiencing very noticeable surging during cruise with a steady pedal - TPS typically ~5%, otherwise it runs fine. Studying logs and all I'm seeing jump around near the surging are the NB O2 readings, no AE no Decel and not a wide range of WB AFRs readings. Anyway it's on the market and I'm trying to work out the kinks. Looking for some direction on where to look for clues on how to resolve.
Advised to jack VE and lower SA in the surging ranges - I did but no improvement noticed.
Running closed loop. Some info - "84 Crossfire Corvette, 383 Stroker, Aluminum Heads, Headman Headers, Renegade Manifold, 90# Injectors, Vacuum Referenced Fuel Pressure Regulator (FP set @28), DUI AMC Street/Strip Distributor, MSD 6A Capacitive Discharge Module, Dynamic EFI Programmable Tuning ECM
Thanks.
Old Jun 26, 2022 | 09:38 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Re: Surge at Cruise
Must have phrased this wrong based on lack of responses. I have BINs where surging is not an issue but overall not as well performing. I'll keep plugging away at and comparing logs. Will post solution if I stumble on it. Meantime it's on cargurus....
Old Jun 28, 2022 | 06:34 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Re: Surge at Cruise
Bigger issues now - won't start. Throwing malf code 51, Bad Eprom. Advised I need a new EBL Flash System...
Old Jul 29, 2022 | 12:07 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Re: Surge at Cruise
Just a follow-up on this mess - After I changed the spark plug wires and went back to the stock HEI Ignition (was an MSD Capacitive Discharge with DUI HEI coil) the surging went away. Why? No clue. Also virtually eliminated frequent knock counts at high RPM and load. ...and it idles mucho better. Go figure... BTW could not feel any change (decline) in performance.
Save $$$ keep your stock HEI?? Yeah, maybe... could have been the old wires though that were causing the issues.
Cartrax
Sep 27, 2021 10:40 AM
beast94
Oct 12, 2012 09:34 PM
fiveoformula
26
Apr 25, 2012 11:57 PM
LoudmouthSS
Aug 4, 2009 07:15 PM
Slewis
Aug 3, 2008 03:42 PM
