Enabling Lean cruise in the '746 ecm
Old Aug 4, 2009 | 09:30 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Im running the bin AXKW in tunerpro, mask is 61v2. Wondering if lean cruise needs to be enabled or if its already on? If it needs to be enabled, how do i go about turning it on? I thought there was a flag for open loop afr but i don't see anything like that.
Old Aug 4, 2009 | 07:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Enabling Lean cruise in the '746 ecm
The qualifiers for lean cruise are scattered about. And, some of them have a dual purpose. The easiest way to see if the ECM goes into lean cruise mode is with a WB. If the AFR increases into the 15 - 16 to 1 range, then it is in lean cruise.
Note that the qualifiers look at CCP DC%, EGR, CTS, VAC, MPH, MAP errors, and closed loop active.
RBob.
wigmobile
Feb 26, 2025 02:56 PM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Reese-J
Sep 14, 2015 02:43 PM
