383 Xfire Best AFR's for Performance
Old Aug 20, 2021 | 10:10 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Zeroing in a decent tune and looking for recommendations on target AFRs. At WOT I'm getting mid twelves with an occasional dip into the 10's, cruising right around 15. "84 Vette, 383 Stroker, 90# TBI injectors on a Renegade, mild CAM upgrade, and EBL ECM from Dynamic EFI. Wondering if I should be running richer on cruise. Perhaps there's a table someone can point me to... Thanks.
Old Aug 20, 2021 | 10:47 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 383 Xfire Best AFR's for Performance
I cruise as lean as possible without misfire. In the 16-17:1 range.
Old Aug 20, 2021 | 01:10 PM
ULTM8Z's Avatar
Me too... about 16 to 16.5:1.
Old Aug 20, 2021 | 01:40 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
So those guys are cruising in a lean burn for fuel economy. The other option with cruise is tune for torque and you'll end up somewhere between 14.3 and 14.5, probably Stoic is about 14.1 - 14.3 with typical gasoline that has a little alcohol content.
The more racy your engine the more you'll need to help driveability by tuning for torque.
Old Aug 23, 2021 | 01:33 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Yes, thought so I'm going for performance not economy.
Old Aug 23, 2021 | 02:05 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Can you explain what "tuning for torque" means?
Old Aug 23, 2021 | 03:36 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Fuel delivery that results in max torque of engine.
You can tune the entire part throttle fuel and spark map on a Mustang dyno. Command the dyno to lock at a certain RPM and it will hold that no matter what you do with the throttle. Tune fuel for max torque. Repeat at different RPMs and load until you're done. Then go to your spark timing map and do it all over again. The whole process takes like 15 minutes if you can change things on the fly like with Holley EFI.
You'll drive away with part throttle response like you never thought possible.
Old Aug 23, 2021 | 09:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Will burn way more gas and create much more carbon that way too. You can run lean at light loads, lower rpm and crusing conditions and still have perfect throttle response and quick torque delivery when needed.
Old Aug 23, 2021 | 09:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yep.
Old Aug 24, 2021 | 07:25 PM
DynoDave43's Avatar
Thanks guys. Good to know.
Old Sep 26, 2021 | 03:46 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
IMO, get with Rob aka: Street Lethal on here and ask him if he will dial it in for you for max performance. He IS the bomb for EBL tuning and I am working with him on my new tune for my motor. Even though mine is not done right now, it runs really nice so far and he thinks that I should be able to get into the 11s with mine, but that is yet to be seen and would settle for and be ok with a 12.20.
Old Sep 27, 2021 | 08:18 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
An awesome ET for a Crossfire. Getting Rob's help... invaluable. Thanks. Short note - Was at a recent local car show with an NCRS event, obviously did not enter the NCRS thing but I displayed my car. Only Xfire out of over 100 Vettes. Told one the officials I should get an award for being the only Xfire there. He sarcastically replied "I'll give you the Xfire award". I refrained from physical and verbal retaliation. Like I could have said, "This is special Crossfire... (expletives omitted) ". Instead I let him get back to his exciting endeavor of looking for correct bolts on someone's undercarriage.
Old Sep 27, 2021 | 10:40 AM
Buccaneer's Avatar
Axle/Gears: 3.31
That sounds about right from some of those guys. CFI always gets a bad rap...until they get PUNISHED by one.
Johnny Blaze
Jun 25, 2005 12:51 AM
Damien00677
Sep 14, 2004 10:51 PM
demon138
Jul 11, 2003 04:46 PM
badazz84camaro
Feb 25, 2003 06:15 AM
lancer5067
Jan 1, 2002 06:23 PM
