Is this memcal repairable?
Old Jul 16, 2022 | 05:36 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
I got around to trying to start my 91 trans am and it would just crank and not start….I noticed when I messed with the computer it would start and sometimes it would jot. So I took the memcalnput and found that some of the pins where jotakimg contact. Is this repairable?
Old Jul 16, 2022 | 09:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Is this memcal repairable?
might touch up all the prom solder points, the knock filter definatly needs to be touched up . Any idea engine modifications if any ? That’s a 350 automatic memcal someone has attached a flash based eeprom to . Not sure why the knock filter is pried up won’t mess with starting.
Old Jul 17, 2022 | 12:26 AM
Engine: 350 tpi
It has no mods that I know of. I have owned the car for about 10 yrs. It’s just a 350 tpi car. Me either but it started and ran like crap but when I pushed this down and it made contact the car idles perfect and the ses light went out. I only checked it because when I turned the key both fans would kick on so I figured it was in limp mode. And as soon as I messed with the memcal it fixed and then went back to stuttering once I pulled it up
Old Jul 17, 2022 | 10:15 AM
Engine: 350 tpi
I think they puts that eprom too bypass the vats system on it now that I remember.
Old Jul 17, 2022 | 10:25 AM
Engine: Lb9
Transmission: M20
A few ways to fix, get a moates d2 unsolder the chip
firmly solder in the d2 . Clean the legs of the sst eeprom and stick in the d2 dip socket. Or use a g1 and bypass the prom but would need a burn 2 burner and a sst eeprom. It looks like when they added the chip they attached to the original proms legs so it still can be salvaged and removed. Not sure why someone would unsolder the knock filter board.
Old Jul 17, 2022 | 11:56 AM
Engine: 350 tpi
I actually have a chip burned for it I’m using the moates adapter it was running perfect by then started to give me problems I have the one that locks into place I’ll snap a picture so you can see it.
Old Jul 17, 2022 | 11:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Odds are it is the ECM that is bad, not the MEMCAL. Press on the ECM board in various areas and see if the same issue pops up.
RBob.
Old Jul 17, 2022 | 12:04 PM
Engine: 350 tpi
Old Jul 17, 2022 | 12:11 PM
Engine: Lb9
Transmission: M20
The chip is in the zif backwards, you can remove the zif and socket that eeprom into the dip on the g1 notch towards the nearest outside edge. Or like rbob said could be a bad ecm
Old Jul 17, 2022 | 12:16 PM
Engine: 350 tpi
Ok I will start to troubleshoot to see if it’s a bad ecm. You mean the little black chip needs to face the other way?
Old Jul 17, 2022 | 12:18 PM
Engine: Lb9
Transmission: M20
Yes the chip on the piggyback is backwards
B4CHawk
Members Camaros
35
Oct 20, 2015 05:15 AM
Daytona_83
May 31, 2011 03:41 PM
TraviZ
Northern California
36
Jan 19, 2006 11:27 AM
Scooby
Mar 15, 2004 09:18 PM
white91formula
Mar 7, 2004 08:37 PM
