Northern California Discussion board for Northern and Central California.
engine misc photos
Old Dec 28, 2005 | 11:12 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
engine misc photos
heres some photos. u can see the quality difference between a eagle and gm crank. not to mention the custom swiss cheeze job on the crank i pulled out
lol.
Old Dec 29, 2005 | 01:05 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
swiss cheese is yucko
eagle pretty : drool :
Old Dec 29, 2005 | 01:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Someone had to take a lot of mass off that thing for some reason.
Old Dec 29, 2005 | 01:18 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
practice? lol or another method called lightening up the assembly.
Old Dec 29, 2005 | 01:34 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Originally posted by TraviZ
lightning up the assembly.
U had a F**d Lightning crank in there?
Old Dec 29, 2005 | 02:52 AM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Damn, what a difference, makes me want one now. GM sh*t sucks.
Old Dec 30, 2005 | 01:05 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well after purchasing new main bearings. and test fitting the crankshaft, thier is one little corner of the block that the crankshaft does not clear. its along the oil pan rail, rear of the block, the counterweight of the crankshaft comes in contact with the block at the corners of either side of the counterweight, not sure how much i wuold need to clear on the block to make it slide by. ive got about a lil under a 1/4" from the oil pan bolt hole to the end of the block. think its safe to file the block closer to the hole? iw ould hate to have oil leaking issues. or should i have the shop chop up my crank to make it fit, while they are balancing it all?
Old Dec 30, 2005 | 10:26 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
just have the shop clearance the block.
Old Dec 30, 2005 | 12:16 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Have the shop take care of it,that it way it'll be warrantied.That would suck to get everything together just to find out ya ruined something.
Old Jan 2, 2006 | 07:33 PM
Car: 07 Silverado
I second that.
Old Jan 2, 2006 | 07:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I just clearenced the block today, easiest thing in the world. all you are *******, or have never done it before. lol . bout as easy as changing oil, no wait.. its easier then that cuz you dont gotta crawl under the car. took all of 5 minutes once i prepped it.
jesse, i gotta stop doubting you!
Old Jan 2, 2006 | 08:57 PM
Car: 07 Silverado
Sweet bish, way to save some money. Now you will have to do mine someday.
Old Jan 5, 2006 | 09:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
more pics!
hey guys, assembled the engine to check for clearence, here is some pics what its gonna look like when its done. i have to now dissasemble it again so i can send it away for balancing. just had to make sure no rod bolts were gonna hit the cam.
Old Jan 5, 2006 | 11:17 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Re: more pics!
paint that ugly engine
Old Jan 5, 2006 | 11:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ill get to it. dont worry, once i tear it apart again.
Old Jan 6, 2006 | 09:54 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Travis, Check fit your pan now. I had to pound the stock pan out and the bolt near the notch was hard to start.
Don't forget the rotating assembly does stretch (very little) at high RPM's so be sure you have some extra clearance.
Looks good so far!
Old Jan 6, 2006 | 10:26 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
everything does clear good, thier is a little place where the damn counterweight at the back rubs against the pan, so im gonna have to beat the pan out haha. thanks for the tips dwayne!
Old Jan 6, 2006 | 10:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: more pics!
You don't have a timing set on in the pictures. Did you check for clearance with the timing set installed?
Old Jan 6, 2006 | 10:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im doing that tonight. thanks for the pointer though.
Old Jan 7, 2006 | 11:04 AM
ratrodjon's Avatar
Car: 89 CAMARO, GUTLESS WONDER
Engine: 305 TBI
Did you hurt your last engine, or just upgrading? What cid, heads, cam, and what size shot are you going to throw at it?
btw I might cruise to tahoe, the paints falling off my car at exponential speed so every one elses cars will look great in comparison, I won't charge much for the photo ops!
Old Jan 7, 2006 | 12:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
if you read to my left here, thats my engine im building as shown in the pics above.
my last engine had a rod break and piston explode.
Old Jan 8, 2006 | 08:30 PM
ratrodjon's Avatar
Engine: 305 TBI
Oh ***, I'm blind Nitrous is a great rotating assembly test
Old Jan 8, 2006 | 08:35 PM
ratrodjon's Avatar
Engine: 305 TBI
whoa! they censored the word G.O.D? Thats offensive? do they censor ala, budda, ra, or cow? Can anyone say religious oppression?
Old Jan 18, 2006 | 03:54 PM
Car: 07 Silverado
Damn, looking good Travis. What color are you going to paint it? Don't tell me fairy red, lol? Anyway, hope to see it all up and running soon, good luck, oh and I get the first ride bish.
Old Jan 18, 2006 | 05:48 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i bought some vht high temp silver paint to help match all the aluminum components.
Old Jan 18, 2006 | 06:03 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Are you going to clear coat it too?I did my old 355 in Chevy orange and clear coated it and it looked awsome.I have a pic somewhere.
Old Jan 18, 2006 | 07:13 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i wasnt going to, should i? is thier a vht high temp clear ?
Old Jan 18, 2006 | 07:16 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Vht makes high temp primer,base and clear for engines.
Old Jan 18, 2006 | 07:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i guess ill prime it too then/
Old Jan 18, 2006 | 08:13 PM
Car: 07 Silverado
Silver should look nice, glad to hear you are not going to go with red. Clearing it will look sweet and give it that wet look, plus it will be easier to clean up and keep clean over all, like a clear coat on your car.
Old Jan 18, 2006 | 10:09 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Dear Travis,
I was rethinking your sig line.
I think you should put some of the main items back in your 'lil sig. pic to decrease that unsightly paragraph below your avatar, thereby shrinking the amount of space each reply of yours leaves.
Possibly advertise that mean 383/HSR/heads/cam
Just a thought.
Sincerely,
- Del
p.s. - the silver is a good idea, any color really, just to renew that old underhood of yours.
Old Jan 18, 2006 | 10:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Happy?
Old Jan 18, 2006 | 10:41 PM
Car: '89 GTA
Old Jan 18, 2006 | 10:51 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yeah,that does look much better.It was hard on the eyes when it was under your avitar.
Old Jan 18, 2006 | 11:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
your eyes are weak.
Old Jan 19, 2006 | 10:47 AM
Car: 07 Silverado
Much better bish, I told you your replies were way to damn long. Glad to hear I am not the only one who had a problem.
Old Jan 19, 2006 | 11:27 AM
Car: '72 Chevy Nova
Transmission: TH350
it angered me as well
Frozer!!!
Jan 19, 2024 04:55 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Aug 5, 2015 11:57 PM
