Northern California Discussion board for Northern and Central California.
Need help locating the right part
Old Jan 5, 2006 | 06:41 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
3.42 rear end.
How much will it cost and how hard will it be to find one?
Old Jan 5, 2006 | 06:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I by luck found one at the junkyard, it was half off day too haha.
3.42 posi disc rear end, 60 bucks!
bout the only time ive ever gotten a good deal.
if u have a 10 bolt now, check into just upgrading to a posi and gears, pick those up new about 200 bucks, and have a shop install it.
Old Jan 5, 2006 | 08:49 PM
Cadillac's Avatar
I'm such a nerd with this stuff. I had some guys on another forum give me some advice on what to get but when it came to the specifics, that's when I got lost.... and where I need help.
My questions:
1.) How do I know if I have a 10 bolt? Count the bolts on the rear of the differential? I know these questions are silly so no "noob" comments Jesse.
2.) Once I know if I have a 10 bolt or not, is there a kit I can buy that will upgrade to to a posi and change the gears? I know there are shims and stuff involved in the installation.
3.) If any of you happen to be at a PNP and see a differential like Travis found, will you accept a 10% finder's fee?
Thanks for the advice...
Old Jan 5, 2006 | 09:08 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I'll be selling mine inabout a month and a half for $250. its a 10 bolt disk brakes 3.23 posi. oil changed once a year and the pattern is check when oil is changed and always look perfect
1.) yes just count the bolts
2.) you can buy a posi and gears and a diff install kit. but its not easy to install yourself send kyle(r1maniac) a PM he does that kind of stuff for a living
Old Jan 5, 2006 | 09:10 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
What do you have in that Mike, 2.73's?
Summit sells the 3.42 carrier set I think.
I'm sure you have a 10 bolt in that TBI.
The RPO code for a Borg Warner 9 bolt is M78 I believe, dunno about 10's.
Old Jan 5, 2006 | 09:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
plus i think they did away with 9 boltsi n 1990.
Old Jan 5, 2006 | 10:37 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Mike definetly has a 10 bolt. probably a non posi 2.73 car though. A 3.42 posi would be a very worthwhile upgrade, it will bolt right in. No more than 45 minutes to an hour on jackstands in your garage. The big thing to remember is that your speedo is going to be off afterward!
And the only stupid question is "Why ask questions?"
Old Jan 5, 2006 | 11:05 PM
Cadillac's Avatar
Oh man... I am interested in that for certain. Please let me know when you are ready to offload it. The only thing is the 3.23 gearing but then again, that's better than the 2.73 in there now but would preserve a little more mileage (like it matters). I'm a little worried about the additional cost associated of upgrading to disks in the back from the current drums. Another big deal/significant cost?
If I went that route in a month and a half, that would give me time to research buying the kit and talking to Kyle though. I'm guessing this route might cost more. Should I contact him directly? Will he know where to get the right parts?
Veirifed: 10 bolt, non-posi, 2.73
Old Jan 5, 2006 | 11:10 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i would go with terrells axle for now, i dont think changing to discs is too bad. just have the brake lines feed into the caliper instead of the wheel cylinders, hopefully they are the same fitting size.
once that is taken care of then later on you can worry if you want to upgrade to 3.42 from the 3.27 . at least they are the same carrier.
Old Jan 5, 2006 | 11:11 PM
Car: '72 Chevy Nova
Transmission: TH350
Kyle can probably get these items alot cheaper, but you would need:
Ring and Pinion set: $100-$150 on ebay. Significantly more on summitracing.
Install kit: $75 for me at wholesale.
New posi carrier: How much money do you want to spend LOL $300 and up.
Then at most shops the install price is about $600 dollars. Most shops will bill this at 6 hours time. If you know what you're doing it's SIGNIFICANTLY faster however, but shops don't tell you that.
Swapping for a used unit is much more cost effective if you aren't worried about it being used.
Old Jan 5, 2006 | 11:15 PM
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
last time i went to my local pnp there was a ten bolt disc
rear end ready to be pulled this was bout week in half ago so ill go check for u and let u know i think they want 125 for it had brand new disces and every thing so ill let u know caddy
Old Jan 6, 2006 | 10:30 AM
Cadillac's Avatar
Thanks all!
I appreciate the feedback. Now I know how much money to queue up. I'm going to go search the brake board to see what the drum-to-disk swap would be like.
Old Jan 19, 2006 | 10:45 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
are u looking for a 3rd gen rear end or a 4th gen rear end
Old Jan 20, 2006 | 03:37 AM
JesasaurusRex's Avatar
Originally posted by Cadillac
Thanks all!
i threw some LT1 brakes on my drum rear here not too long ago, PIA but if ya want some help ill be more than glad to talk you through it
Old Jan 20, 2006 | 08:31 AM
Cadillac's Avatar
Hell... whatever works and is the best bang for the buck. Whatcha know?
Thank you, sir. If I get to upgrade to the iron disks from drums I know it will be a big improvement from where I am know. If anything, I'd want to upgrade the fronts next.
Old Jan 20, 2006 | 09:08 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i have a friend that has couple of thirdgen and 4th gen rear end. im trying to remember what he had though. I'll go ask him if he willin to sell them.
Old Jan 20, 2006 | 10:29 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
On my old 87 I had 2.77 /drum rear.I swapped in a 9 bolt 3.23/disc rear.It was easy,couple hours in the garage by myself.You'll need to chang the proportioning valve(5 minute job)Get the brake lines with the axle and just connect those to the junction above the pumpkin and you'll be good to go.It will brake a lot better with the disc and replacement parts aren't much more $$$.
Old Jan 20, 2006 | 03:42 PM
Cadillac's Avatar
Originally posted by 87tpi
On my old 87 I had 2.77 /drum rear.I swapped in a 9 bolt 3.23/disc rear.It was easy,couple hours in the garage by myself.You'll need to chang the proportioning valve(5 minute job)Get the brake lines with the axle and just connect those to the junction above the pumpkin and you'll be good to go.It will brake a lot better with the drum and replacement parts aren't much more $$$.
Did you notice a performance improvement?
And you meant to say it will brake a lot better with the disks not drums, right?
Old Jan 20, 2006 | 04:59 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yeah sorry,I meant to say disc.I noticed a pretty big difference,especially on take off.Accelleration while driving was improved too.I would do it again,actually I'll be doing it in a couple of months.
Old Jan 20, 2006 | 06:03 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Hey where did you get those rings around your gauges?Iwanted some for my old bird but it had a digital dash but the new one will have analog.
Old Jan 20, 2006 | 11:17 PM
Cadillac's Avatar
Check out this thread:
powermite's mods
This dude in the UK went off on his bird. in a GOOD way. Anyway, he fabbed up these bezels and someone on this forum (TGO Member "bnoon") copied the idea and did a run in billet aluminum. He had satin, polished, and raw. The polished ones were $120 bucks for 4 rings. Both Alex and I scored a set before he decided it wasn't making him money. I've had at least a dozen people PM me about them. Brad Noon ("bnoon") should do another run.
I really like what they do for the interior.
Thanks for noticing.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 11:48 AM
