Dynamic EBL guidance
Old Mar 27, 2023 | 10:07 AM
Kens89's Avatar
Hi Guys,
Jumping ship from Corvette Forum looking for some guidance.
Going to convert my 89 Corvette to the Dynamic Flash ECM.
Was wondering is there is a thread to help me along in regards to what WB, MAP sensor, pig tail for the mass air to map etc?
Will also be looking for a close tune if possible, 383, AFR heads, Mini Ram, Hooker Comp.
Always enjoy lining up next to you guys at the track
Old Mar 27, 2023 | 10:14 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Dynamic EBL guidance
Boosted or n/a ? There’s a lot of information on there site. . The install cd has starter tunes but will need to account for displacement and injector flow and offsets.
Old Mar 27, 2023 | 11:35 AM
Kens89's Avatar
N/A, did look at their site but did not see much in regards to recommended hardware.
Old Mar 27, 2023 | 11:48 AM
Engine: Lb9
Transmission: M20
You can get a 1 bar map and pigtail on Amazon, RockAuto,,eBay
for 90-92 tpi sd . I believe the bins are in the download section if you didn’t get a cd.
Old Mar 30, 2023 | 10:07 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
It's an essentially painless process. I always recommend that members get a 2 or 3 Bar MAP sensor ahead of time, as once you see the ease of tuning with the system, you may want to venture into boost, so you'll be ahead of the game. But yeah, the Bins are already there for you to choose from, as is the Utility. Select a Bin for the L98, use the provided Utility to calculate any differences in engine and injector size, update those values, set and/or confirm that your Base Timing is where it needs be, and you're done. As mentioned, pigtails and MAP sensors are available online....
Welcome aboard.
- Rob
Old Mar 30, 2023 | 06:26 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Welcome aboard.
- Rob
WELCOME BACK ROB!
Old Mar 31, 2023 | 06:36 AM
Haha, thanks. Glad to be back...
- Rob
Originally Posted by Buccaneer
WELCOME BACK ROB!
Old Apr 26, 2023 | 11:16 AM
turbo z's Avatar
Car: 88 Iroc-Z Rear mount Turbo
Engine: 5.0L
- Rob
Glad to see you're back Rob!
Don't mean to highjack this thread, but are you still interested in helping with some tuning?
I finally got the TurboZ back running again!
I could really use your help!!!!
-James
Old Apr 27, 2023 | 12:55 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
- Rob
Where did you go?
Old Apr 29, 2023 | 05:02 PM
Notifications aren't coming through for some reason. James sure, if I can help with the tuning let me know. Joe, I see you're taking the plunge into LS land, that's awesome. Might have to fabricate your own turbo headers though, and not work around what's out there. Was forced to buy and alter the ebay turbo headers rather than start from scratch, gotta say though they are definitely stronger and thicker than yesteryear's version that's for sure...
- Rob
-James
Originally Posted by anesthes
Where did you go?
Old Apr 29, 2023 | 11:20 PM
turbo z's Avatar
Engine: 5.0L
- Rob
Thanks Rob!!!!😁
I sent you an email..... But if I got it wrong please email me jcanavan76@gmail.com.
Looking forward to hearing from you!
Old May 13, 2023 | 04:42 PM
???'s Avatar
Welcome aboard.
- Rob
huh. I didn't think about starting with a 2bar just in case.
won't miss the 1 bar resolution for anything?
Old May 13, 2023 | 08:11 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It will, but you don't have a choice anyway if you ever go forced induction.
Modern engine management systems employ multiple fueling strategies, such as a 1 bar MAP and a second 2/3 bar MAP with table switching. Even OEM applications switch between MAP and MAF for drivability. $EE (94-95 LT1) for example has some of the best drivability, and of course all the LSx stuff.
-- Joe
Old May 14, 2023 | 06:39 AM
Not at all, you won't miss anything. The averages you're setting in the Bin don't change in the tables, you just need to tighten them up a tad to keep the averages at your intended targets. I'm running a 3 Bar MAP with a naturally aspirated engine, no problem whatsoever...
- Rob
Old May 14, 2023 | 06:09 PM
???'s Avatar
- Rob
thanks.. I think I might just do that. there's a 90% chance I won't boost it, but you know, I have been looking at that Volvo electric powersteering pump, and if so.. low mound alt and move sanden compressor to the drivers side.. leaves lot of open space on the passenger side.
Old May 14, 2023 | 06:21 PM
turbo z's Avatar
Engine: 5.0L
Or mount a turbo behind the rear differential like I did.
It works very well thanks to Rob and his master tuning skills 😎
Old May 14, 2023 | 07:27 PM
???'s Avatar
is there a build thread?
Old May 15, 2023 | 03:03 PM
I cant run the engine too long because the alternator, though I have it in place, its not hooked up because the 90-92 TPI alternator fan hits the earlier 87-87 serpentine setup bracket. Need to trim the blades down some. I do have a build thread, but I haven't been updating it. I just wrapped up another 305 of all engines, happy with the way it came out, and though I was planning on slapping the turbo on it, now I'm leaning more towards a Vortech. Buy yeah, this is a 3 Bar MAP naturally aspirated. No resolution loss whatsoever. If I can help, or if there is anything you need EBL related, just say the word...
- Rob
https://www.youtube.com/shorts/z32FgbRVFpQ
Cdeez
Feb 18, 2019 07:55 PM
j88l98irocz
Jul 17, 2007 10:34 PM
Marlou
Jun 25, 2007 10:46 AM
Trux
Feb 3, 2003 09:31 PM
Z_Ghost
Apr 7, 2002 06:40 PM
