PROM HELP PLEASE PONTIAC TRANS AM -88
Old Aug 21, 2023 | 02:37 AM
Markus92's Avatar
Hello everybody,
New to this place and need help!
I hope maybe someone here can help me figure out what kinda PROM i have for my Pontiac trans am -88 350 TPI 5.7L.
The thing is i'm suspecting my PROM is starting to failure due to lack of power sometimes when i drive my car.
Could someone maybe point me in the right direction where to get a new one?
BR
Markus
Old Aug 21, 2023 | 08:43 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: PROM HELP PLEASE PONTIAC TRANS AM -88
Is the eeprom soldered in securely? Any codes 41 or 51 thrown ?
Old Aug 21, 2023 | 10:14 AM
Markus92's Avatar
What i can see from the looks it has been soldered sometime in the past, maybe the soldering gone bad.
Regarding the error code 41 or 51. Do i need some special Scan tool to see error codes?
I can add that i’m fairly new to this car.
Or do you have any clue where i can get a hold of a similar PROM?
BR
Markus
Old Aug 21, 2023 | 10:37 AM
Engine: Lb9
Transmission: M20
You can blink the codes by jumping the aldl pin a to b.
if it’s a non vats AKXX or AKXY code, vats would be AKXZ .
im not so sure your issue is a bad eeprom you might be able to find a all stock memcal on eBay for 88 350 automatic.
closest I have in stock form is a 89 vats 350 automatic that would work if you have functional vats.
Old Aug 21, 2023 | 10:44 AM
Engine: Lb9
Transmission: M20
https://www.obd-codes.com/faq/read-g...codes-free.php
Old Aug 21, 2023 | 10:46 AM
Engine: Lb9
Transmission: M20
AKXX here
https://www.ebay.com/itm/27590226746...mis&media=COPY
Old Aug 21, 2023 | 12:41 PM
Markus92's Avatar
Sorry maybe a dumb question because my head is taking in alot of EPROM information atm.
What do you mean by ”vats”?
Also tried to look for the aldl but seems like my car is missing one??
BR
Markus
Old Aug 21, 2023 | 12:44 PM
Engine: Lb9
Transmission: M20
Vats- vehicle antitheft system. Does it have a pellet in the ignition key ?
the aldl should be knee level on the drivers side.
Old Aug 21, 2023 | 12:47 PM
Markus92's Avatar
Another question if got this right, the SST EPROM that is soldered on my memcal is not a original EPROM?
Maybe some program issue then?
Old Aug 21, 2023 | 12:50 PM
Engine: Lb9
Transmission: M20
Could be
Simsalas
Nov 17, 2015 03:35 AM
86_Dan_Z28
May 23, 2010 12:07 PM
Super_GTA
Pacific Northwest Region
Apr 5, 2008 04:42 AM
