ECM or not to ECM?
Old Nov 1, 2023 | 07:36 PM
mjgord51's Avatar
Car: 14 & 96 Camry's, 68 C10,70 Z28
Engine: Depends what vehical I'm driving
Transmission: Also depends which vehical
Axle/Gears: Also depends on vehical
ECM or not to ECM?
I have a transplanted 1988 305 ci motor and a 1992 4L60 trans both from a Firebird and I'm wondering if the ECM has anything to do with the TCC lock-up method/system ?
Old Nov 1, 2023 | 08:22 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: ECM or not to ECM?
Yes, the ecm controls the torque converter lock up on that trans
Old Nov 1, 2023 | 08:28 PM
mjgord51's Avatar
I found from another forum the ECM has nothing to do with the TCC lockup and its controlled by vacuum. Now I'm confused.
By the way whats your "expertise' on this subject not beating you up just curious.
Old Nov 1, 2023 | 08:43 PM
What's to be confused by? The lock up was computer controlled on the 92 fbody transmission. It also did on the 88 fbody. My expertise? Like credentials? I'm not bothering to list that out. My expertise, like opinion? Use an ecm or mock up a torque converter lock up using other methods. Vacuum lock up switches were also used.
Old Nov 1, 2023 | 08:44 PM
https://www.thirdgen.org/forums/carb...c-control.html
Old Nov 1, 2023 | 08:55 PM
mjgord51's Avatar
Not Doubting you but this trans isn't a "E" (4L60E) trans these are its casting #'s 8676358 and suffix code #'s are 2FTM098H.
Old Nov 1, 2023 | 09:06 PM
mjgord51's Avatar
SORRY double posted.
Old Nov 1, 2023 | 09:31 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Perhaps you personally should gain some expertise on the parts you bought.
Old Nov 2, 2023 | 07:43 AM
E refers to shifting the gears being electronically controlled. The torque converter lock up is still ran by the ecm in the 88 and in the 92 f body. The gears shifted without the ecm on these cars, hence the tv cable.
Old Nov 2, 2023 | 11:10 AM
mjgord51's Avatar
WOW REALLY that's what your contribution is. Your contribution leaves a bad taste in my mouth because these Forums are to get and give answers and help for people trying to find answers to what they "don't" know very much about. Getting the best/ right information is WHY someone asks questions. I'll ask you this how did you get so smart OH YEAH YOU ASK QUESTIONS TO GET ANSWERS didn't you!
Old Nov 2, 2023 | 11:25 AM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Bit of advice
If you are going to doubt the validity of answers you are being given, maybe state in your original question that you expect a full write up of credentials with any answers being given...will save people from wasting their time trying to help you.
Also a google search of "4L60 vs 4L60E differences" nets hundreds of thousands of results in half a second. You could even search "4L60 vs 4L60E differences site:thirdgen.org" to get specific results from this forum only. That nets about 9,000 results in half a second.
GTA
Feb 21, 2010 09:02 AM
Ripped
Aug 29, 2007 09:00 PM
