question about o2 voltage
Old Mar 11, 2002 | 04:37 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
have a little debate. damon says the higher the voltage reading the leaner the mixture. i say the higher the voltage reading the richer the mixture is. now to support my claim, both my OTC scanners have a led that switches from lean to rich when the 02 go above .5 volts. now unless scanners have been programmed wrong or my teaching is incorrect, the higher the voltage the more unburned fuel is in the exhaust. then the computer reduces the pulse width to lean the mixture. maybe i'm wrong, but i don't think so.
Old Mar 11, 2002 | 07:20 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The higher the voltage, the less O2 in the exhaust due to a richer mixture. The lower the voltage, the more O2 in the exhaust due to a leaner mixture.
FYI, with Highway Mode invoked, I run a "commanded" AF ratio of around 16.4-17:1 and my O2 mV readings are around 60-120 mV.
Old Mar 11, 2002 | 07:22 PM
mrr23's Avatar
Engine: 360 HSR
thank you. that's one for me.
KCG
Jun 24, 2020 04:33 AM
327IROC85
Sep 23, 2015 12:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
