What ECM # do i have
Car: Death Mobile
Engine: 666 c.i.
The ECM is under the passenger side dash. Just remove the "kick panel", and you should be able to see it. You will need to remove a couple of screws. Then you can read the label on the ECM to tell you EXACTLY what the ECM# is.
But, you do realize that your particular vintage of F-body does not modify the ECM for a recalibration of the speedo. You need to do that in the tranny.
efiguy
Sep 27, 2015 01:30 PM
