knock sensor question on a 165 to 730 convertion
Old Apr 13, 2002 | 07:54 PM
88_vette's Avatar
I and converting to a 730 and know the knock sensor is different for the 90-91 cars. I've read that the ohms are what makes up the difference? if this is so, can I just run a direct wire from the 165 version knock sensor and put a resistor inline to cut the ohms back?
Old Apr 16, 2002 | 07:14 PM
Jza's Avatar
Jza
According to Mike Davis' site (big help!), he used a resistor between 3.8K and 4.8K ohms to accomplish what you describe.
http://www.cis.udel.edu/~davis/z28/e..._730/165KS.txt
Old Apr 16, 2002 | 07:35 PM
92RSB4C's Avatar
I discovered this site one day. http://www.cruzers.com/~ludis/p4xref.html
New Knock Sensors are only $20-$30 and a little bit of elbow grease. It might be the way to go, but I don't know.
Old Apr 16, 2002 | 08:21 PM
88_vette's Avatar
Thanks guys. I got a 90 vette knock sensor and that fixed it.
No more code 43 or any code for that matter. But car runs like *&^%... It will even stall most of the time. I'm also getting a good amount of white smoke out the exhaust. What's that caused by? Any ideas of somethings to check, and/or do?
Old Apr 16, 2002 | 09:37 PM
92RSB4C's Avatar
I think white smoke is antifreeze but I may be wrong.
Old Apr 16, 2002 | 10:07 PM
88_vette's Avatar
I was thinking the same thing, but the white smoke goes away with the 165 ECM in. Isn't this stuff fun.
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
