$8d PE table question
Old Apr 19, 2002 | 10:26 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
it says rpm on one side of the graph..what does the data represent (rpm vrs ???)
Old Apr 19, 2002 | 10:42 PM
Z_Ghost's Avatar
One is
PE% Change to Fuel/ Air Ratio VS Coolant Temp
the other one is
PE % Change to Fuel / Air Ratio VS RPM
It is how much fuel is added at that RPM when in Power Enrichment
Old Apr 19, 2002 | 10:50 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
What aboout the table listed under arrays as
Power Enrichment?
Old Apr 19, 2002 | 11:06 PM
Z_Ghost's Avatar
What program are you using?
I am using Tunercat .
You have TPS Threshold for Power Enrichment VS Coolant Temp
Table of differential percent throttle position thresholds to enable enable power enrichment (PE) mode Vs. RPM when the coolant temperature is above the value specified by the Minimum Coolant Temperature for High Temp. PE AFR constant.
You have TPS Threshold for Power Enrichment VS RPM
Table of differential percent throttle position thresholds to enable power enrichment mode vs. RPM.
They are for adjusting the how far you can push down the throttle before going into PE mode.
I do not have anything that says arrays.
Old Apr 20, 2002 | 12:14 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
in win bin
Old Apr 20, 2002 | 08:24 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Originally posted by CustomX
in win bin
Who ever defined that table in "WinBin" didn't properly describe it. If you give me the address it is affecting in the BIN, I will tell you which table it is. Or, you can look in the $8D hack for the address and see the exact table it's hitting.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
