help : PROM removal
Old May 3, 2002 | 07:38 PM
Adam62083's Avatar
help : PROM removal
How do you take the PROM out of a ECM. I have to take mine out and put it in another one. Is it just a unplug and plug in type thing, or is there more involved.
Old May 4, 2002 | 01:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you can't figure it out once the ECM access door is off, I fear for your future.
Old May 4, 2002 | 04:58 PM
91-ZZ4-Z28's Avatar
First disconnect the battery.
The ECM is under the pass. side dash.
remove the three screws that hold the lower dash cover and remove it.
If you are lying on your back looking up under the dash it is to your left in a white plastic bracket
it has Velcro holding it in so just push it out a little and slide it out and down
there are two screws that hold the cover on I think they are 8mm
once you have the cover off make sure you are grounded and press on the tabs on each side of the PROM it will pop out
there is a small grove on the top so can't put it in the wrong way just line it up and push with one thumb on each side and the tabs will seat and hold it in
then just put all back
This is about the only question on this board I am capable of answering so I figured why not
:lala:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
