Which table for start up? 6E
Old May 15, 2002 | 11:40 PM
87_TA's Avatar
Would someone be able to tell me which table i should modify
for my car to start easier?
Since ive gotten my BLM's in the ballpark the car stays running now after start up but still takes about 5 seconds of cranking
before it fires.
What table would be suggested to start on and which way to move?
Old May 16, 2002 | 12:01 AM
drive it's Avatar
Re: Which table for start up? 6E
before it fires.
Check the crank fuel PW multiplier vs referance pulses (1-16). If 1 thru 8 is still at 0, then that's whats causing the long crank.
Old May 16, 2002 | 07:06 AM
87_TA's Avatar
Thanks,
Those are all at "0" - would you recomend changing 1-8 to
.5 or higher?
Old May 16, 2002 | 08:45 AM
LS1thunder's Avatar
Move the .5 to the first two slots( + or - ). Then fill in with whatever your stock bin has behind the .5 values, I believe its .25. Thats what I did and it seems to work. Good Luck.
Old May 17, 2002 | 02:09 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Here's what i did, works great starts very fast...
Old May 17, 2002 | 05:29 PM
87_TA's Avatar
Thanks Guys,
Working on as I speak.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
fasteddi
Sep 2, 2015 10:29 AM
htrdbmr
Aug 18, 2015 12:58 PM
