Why does it...
Old May 17, 2002 | 09:05 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
Why does it...
Stall? It will run fine for a while then out of the blue stall. It seems as though after I make a 1/4 mile run it will not idle on its own. I have to just apply a little gas for it run. If I leave off it will start surging then stall.
I upped the TPS EGR to 99% disabled it in the switches table..
It appears that the AIC is working OK. Counts are between 25-40.
It really does it when I run the car hard....
Any ideas..I have read and read, but most of the posts are pretty general.
Thanks.
Old May 19, 2002 | 12:31 PM
ski_dwn_it's Avatar
ttt
Old May 19, 2002 | 01:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Why does it...
!/8-1/4 turn at a time, srew the min idle speed srcew in. And not the change to your IAC. What I like to do is set the commanded idle speed to a fairly low number, and then set the min idle speed screw to slightly higher then that. That way reguardless of what the IAC does the engine shouldn't stall. And you want to turn the screw just slightly, and drive the car, don't just let the engine idle and twist the srcew expecting the idle to change, and stay there. I turn the engine off make an adjustment, drive the car and then note the change after 1-2 of low speed driving.
Old May 19, 2002 | 02:07 PM
ski_dwn_it's Avatar
Thanks grumpy I will try that!
Old May 19, 2002 | 04:40 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Re: Re: Why does it...
Is that going to cause the IAC count at idle to be 0? I thought you wanted a few counts at idle...say 10 or so.
Old May 19, 2002 | 05:13 PM
ski_dwn_it's Avatar
Thanks grumpy. I will give her a try.
okfoz
Oct 13, 2015 02:19 PM
85cmroz28
Oct 4, 2015 09:44 PM
luvofjah
Sep 26, 2015 08:28 PM
CORV3TT3
Aug 23, 2015 11:26 AM
CD MaroMan 91
Nov 28, 2001 04:45 AM
