adjusting MAF tables will upset timming?
Grumpy advises not to adjust the MAF tables to alter fueling. Could a reason for this be that LV8 is calculated from MAF and RPM so if you change the MAF table it will alter LV8 values and so alter ignition timming?
For example most of my MAF tables are set to zero to prevent gas flowing as I use propane. Problem is the ECU doesnt see any load on the engine so I can only adjust timming against rpm and not LV8 also.
Simon
Simon
Thanks for replying KVU.
I'm sure there are a lot of other things I have not considered with my setup. However my car is running great at the moment. Never seen another camaro in the UK to compare with though.
I run on propane only to a certain airflow above which I need to add gas otherwise mixture is lean. I'm not sure if adding gas at a certain rpm value would work as it doesnt take into account load. But there again is MAF voltage proportional to fuel demand?
My method of adjusting the MAF tables is to look at a voltmeter monitoring MAF voltage and lambda voltage as I accelerate hard. When the mixture goes lean I note the MAF voltage and add gas at and above that point. So now when I accelerate the mixture never goes lean. Small increases in the MaF tables hopefully means I'm not too rich.
I have not considered converting to a SD system as parts are not available here. Well not cheaply.
Simon
Simon
I'm not an expert on sd or propane but I think speed density would work like a dream.I have seen positive results using the maf tables though.Thats just minor changes.But for your app,I think slamming the table(s) might have a dramatic effect on lv8.I'm not saying your car does'nt run good.Just that sd would really make it come alive.It's an easy swap.All you need to buy is an ecm,prom and map sensor.Many gm cars have 730 ecms in them. You just need to find certain 90's fwd car in the salvage yard.I can get one for $20 round here.The prom is $40 through gm,I think.I'm not sure how much the map is,$20 maybe.It might be something to look into.When your maf goes it will be $150.Thats why I'll be doing the swap.
BumpaD82
Feb 26, 2016 02:57 PM
86CamaroDan
Sep 29, 2015 10:08 PM
