built a couple cables...but i want a better one, but i need some info
Old Jun 15, 2002 | 08:36 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i built my most recent cable using some monster audio cable i had laying around the garage. it is really high quality wire, and is 12 gauge. right now, the cable is about five and a half feet long. is this too long? ihave had problems in the past with missing data points becuase of (i think) a bad cable.
what is the optimum length of a cable? what type of wire?
also, in the interest of making it easier to hook up, i want to have a "permanent" connection to the aldl connector, and run a couple feet or cable to the ashtray with a weatherpack connector. is this a recipe for disaster or what?
i know that the cable are pretty touchy as far as length, RFI, etc. goes, but i want to make it as easy as possible to actually use.
what do you guys think???
(and, yeah, i did a search, with no real sign of help..)
-Brian
Old Jun 16, 2002 | 02:31 AM
Chop_Top's Avatar
I have been using a trailer connector soldered to the back of the factory one and about 8 feet of telephone wire and have no problems at all.
Anything better shold work just fine.
Old Jun 21, 2002 | 08:53 AM
BillD91RS's Avatar
Chop_Top do you have any pictures of your connections?
Old Jun 21, 2002 | 01:05 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It sounds like you are talking about a scanner cable. If you are what the h$ll are you doing using 12 gauge wire?
Old Jun 21, 2002 | 01:11 PM
Chop_Top's Avatar
I'll put one up when I get home tonight
Old Jun 21, 2002 | 09:41 PM
Chop_Top's Avatar
It's fairly long, didn't measure it, and transistor is in the rs232 end piece. It works very well.
Old Jun 21, 2002 | 09:43 PM
Chop_Top's Avatar
I would like to try disconnecting or adding a switch to my 10K resistor. There are several posts that say the info will flow with out it. As it is, with it in, it idles at 1000 rpm and and some other things I haven;t figgured out are happening.
morrow
Jan 13, 2024 12:29 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
masonta
Sep 1, 2015 06:40 PM
