What causes the idle to rise to around 1000rpm??
Old Jul 18, 2002 | 05:08 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Hi guys,
Can someone tell me what causes the idle to rise to 1000rpm when the adld cable is attached to the car? This "high idle" mode causes my tranny to get hot really fast!
Question # 2
With my trick flow heads, does the stock timing (sometimes going up to 41 degrees) need to be so high?
Question # 3
With the base timing set at 5.98 do I need to add this # To the rest of the timing chart?
Old Jul 18, 2002 | 05:58 PM
kevinc's Avatar
Car: 1982 Z28
Are you attaching the ALDL cable before or after the key is in the <RUN> position?
If you jumper the diag pins on the ALDL connector after the engine's running it drops into diag mode which opens the IAC, activates the fans, and a few other things to my recollection.
Connect the cable with the key in <OFF> and re-test with the scantool connected and powered.
Old Jul 19, 2002 | 04:43 AM
86Tra/maro's Avatar
Before or after, it doesnt matter the rpms rise to 1000 rpm Ive tried connecting with the car off also, still the same thing.
Old Jul 19, 2002 | 09:40 AM
kevinc's Avatar
Car: 1982 Z28
What kind of scanner and cable are you using?
Old Jul 19, 2002 | 11:48 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Only for your information:
There are a mode named "battery mode" in which the idle to rise the necessary RPM's in order to compensate a low battery voltage (it can be a bad connection at bat. terminals too).
Regards,
Denis v.
Old Jul 19, 2002 | 06:11 PM
86Tra/maro's Avatar
Im using win ALDL, & the cable I brought from AKM cables.com.
Denis V,
It only idles high when the cable is hooked up. As soon as the cable is removed it goes right back to the normal idle.
Old Jul 21, 2002 | 01:00 PM
Morley's Avatar
Denis V,
thats because of the 10k ohm resistor in the cable that puts the ECM into ALDL mode which locks the idle to 1k, just another GM design that makes you wonder.
Old Jul 22, 2002 | 04:15 PM
86Tra/maro's Avatar
Thanx Morley!
junior419
Apr 7, 2025 11:35 AM
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
