question on VE tables after camshaft install.
Old Jul 23, 2002 | 03:53 PM
KYL98's Avatar
Car: 1991 Z28
I am new to PROM burning so please forgive me. I am wanting to install a LT4 HOT cam in my L98, but from reading posts on the board, I know my MAP sensor will go crazy? My first question is, is it hard to go in and change the VE tables without messing anything else up? Also, might there be anything else I would need to change/adjust for the differences in vacuum, etc? Any help on this would be greatly appreciated. I know the mechanical part of Chevy very good, but the computer end is tricky for me. Thanks guys.
Attached Thumbnails question on VE tables after camshaft install.-camarosideview1.jpg
Old Jul 23, 2002 | 10:48 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You need to tune the VE tables as per the "P730: Part throttle tuning" sticky post above.
Old Jul 23, 2002 | 11:31 PM
funstick's Avatar
if unstable vacum is a problem then install a vacum resivor inline to yr map. itll make the map react a little slower but will smooth out some of the intake reversion. its worked on a couple of cars ive worked on so it might help you or not. depends on how much reversion and overlap you have. but heys its worth a try. ive used the vacum bulbs out of lincoln town cars with great sucess the 88-91 5.0 lincolns had a steel coffecan looking vacum can that also works well.
Old Jul 24, 2002 | 05:41 AM
87_TA's Avatar
Starting with the LT4 cam you may want to drom lower VE tables from 3000 and below by 15% to start because you will probably be rich right off the bat .
Old Jul 24, 2002 | 05:55 PM
IROCZ88's Avatar
Here is the easiest way to get your VE tables close.
1-Buy Tunercat
2-Buy a cheap laptop
3-Buy a cable and Datamaster from AKM
4-Download VEmaster
5-Do a search on these items/software to see how to use VEmaster
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
blackroc68
Sep 1, 2015 08:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
