8746 woes - any problem in a 1988 car?
Old Jul 24, 2002 | 07:05 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
I just tried transplanting my 8746 with a custom chip into my 1988 sport coupe with a 350 and the car won't start - it just turns over and over and over and....u get the idea. Is there anything one could overlook? I just replaced the 8746 chip with my new one and plugged it in - i'm figuring it should work. Any help would be great - thanks again.
Tyler
Old Jul 24, 2002 | 07:38 PM
steve8586iroc's Avatar
Did you check the pinouts? How about the stock chip?
Steve
Old Jul 24, 2002 | 07:55 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
the pinouts? if those are the metal pins in the computer that the harness plugs into - its fine. And i wasn't sure to try the stock chip in the computer b/c the only chip i have left is for the OLD computer which isn't a 8746, its a 8036 or something. Argh
Tyler
Old Jul 24, 2002 | 08:42 PM
Brent's Avatar
If VATS is enabled in the 8746 PROM you will have a no start condition.
Old Jul 24, 2002 | 09:05 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
so with the vats the car will just crank over but won't fire/start correct? So if its disabled then my car should run???? What is vats anyway?
Old Jul 24, 2002 | 10:05 PM
Brent's Avatar
Correct
Correct, if that is the only problem.
An anti theft system. A quick search of this board for "VATS" will get you the specifics. The FAQ off the main page contains some info too.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
