Code 24 (VSS) doesn't make the computer go into limp home does it?
Old Jul 26, 2002 | 11:05 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'm getting a code 24 b/c my speedo is not working, I'm not cruising in limp home am I?
Old Jul 26, 2002 | 01:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Limp Home Mode, contrary to popular belief is only when the processor fails.
Your running in Soft Failure Mode.
Fix your speedo...
Old Jul 26, 2002 | 01:58 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Hey Grumpy, will you explain soft failure mode further? Thanks!
edit: Which codes trip you into soft failure mode? I have had little luck finding in the searches and I am very curious.
Old Jul 26, 2002 | 04:48 PM
leirch's Avatar
As my understanding, soft fail is when the ecm sets ANY code... when you see the SES light flashing rapidly and cannot link up to that, thats hardware failure mode or limp home mode(yes I've seen it before, not a good running car at that point )
I think grumpy did a big long post about limp home and fail safe mode a while back.
Brendan
Old Jul 26, 2002 | 09:25 PM
JMatlock88's Avatar
Car: 1991 Formula
Okay, thanks lierch... I will search his posts!
Old Jul 27, 2002 | 10:01 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Brendan
Just to expound on it, it's when an input is out of range and the ecm uses a default setting.
There a couple different ways the SES is handled, slow blink, fast blink and then steady.
Limp Home is when your just running on the module timing, and reduntant fuel devise..
Old Jul 27, 2002 | 09:22 PM
BuckeyeROC's Avatar
Just out of curiosity, what default setting would be used for the vehicle speed? I know the TC is not locking up b/c of this, anything else the computer needs the VSS for?
Old Jul 29, 2002 | 12:52 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I searched and could not find his post on this. I want to know what happens when my o2 sensor bites it or my cts? What happens if both go? There must be some sort of protection for the engine, right? Pull timing, more fuel? Thanks
Old Jul 31, 2002 | 08:30 AM
leirch's Avatar
https://www.thirdgen.org/techbb2/sho...highlight=limp
Here is the link to Grumpy's post. I just searched for "limp". It was about half way down on the first search listings if this link doesn't work.
Brendan
Old Jul 31, 2002 | 10:14 AM
Car: 1991 Firebird
Engine: 427 LSX
Ok, but that doesn't help me with my question.
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
