Engine Temp and TC l/u
Old Jul 28, 2002 | 09:18 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Is there a prom setting that controls what temp the TC will lock up? I used to have a Thermomaster chip that would lock up fine, but after the motor swap, I changed the chip and since then I have only been able to get it to lock a couple of times. When I had my desktop hooked to the ALDL it idled at an even 170 after 10 minutes of idling so I'm sure that it is running a bit cooler when I'm only the road but can't verify what temp cause I don't have a laptop so I can only go by the gauge which reads about 150-160 going down the road. Could I be on the right track?
Tom
Old Jul 29, 2002 | 08:13 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Engine Temp and TC l/u
Yes.
Old Jul 29, 2002 | 08:19 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Do you know what the factory setting is?
Old Jul 29, 2002 | 11:19 PM
JPrevost's Avatar
Car: 91 Red Sled
60c or ~140f, that's the threshold in the ANLU and ANTT eproms. It's where you want it to be. By having the tc "loose" the engine will get up to temp faster. I guess if you wanted slightly better gas milage you could have the enable temp lowered. I moved my enable temp to ~100f.
Old Jul 30, 2002 | 01:01 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I just want to get the thing to lock period. I don't wanna end up cooking my trans over time by overheating it.
Old Jul 30, 2002 | 08:53 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Put a 180 thermostat in it, and tune it for best performance.
Using a cold thermostat for tuning, isn't a good answer.
If you want to change it, in the code, then find a hac for your ecm, and read thru it.
Old Jul 30, 2002 | 10:26 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
You lost me with that. Could you explain a little more about what you mean?
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
