Is it total advance or not?
Old Jul 29, 2002 | 07:06 AM
Carl90's Avatar
When I look at the Datamaster displayed advance on my 90 vette, it corresponds to:
= Base Spark Table + PE advance when in PE mode
Is this total advance? or do I need to add the initial advance of 6 deg to get the total advance?
I suspect that it is total advance, because the factory PROM has 34.8 degrees of advance (Base + PE advance) @ 4800 rpm/WOT. If you were to add 6 more degrees that would take it up to 40.8 degrees, which seems excessive.
Carl
Old Jul 29, 2002 | 11:59 AM
88GTASTK's Avatar
I read the Datamaster as total timing. I know when I check the timing at idle to the balancer it reads total.
Old Jul 29, 2002 | 04:33 PM
Carl90's Avatar
88GTASTK,
At WOT, what does datamaster say your maximum advance is?
With a custom chip, mine says 32 deg at 5200. I am not sure if want to bump up the total timing, if it is truly 38 deg (32 + 6 base)
Just took off my heads for a rework. Later, I'll have to see if I get the same thing that you got at idle.
Carl
Old Jul 29, 2002 | 09:32 PM
88GTASTK's Avatar
Mine says 26 degrees @ WOT. I've backed out the timing tables.
There are some correction / offset things going on at different times that I'm not 100% sure of yet.
Old Jul 30, 2002 | 07:47 AM
Carl90's Avatar
Your advance reading looks low to me.
Datamaster reads 29.9 deg at 4800 and up @ WOT on my car.
Comparing to my PROM tables, this value corresponds to
= main spark table (extended) + PE advance - retard for knock (=0)
If I add 6 degrees of initial to the reading, I get 35.9 deg, which is where I would expect to be. I suspect that the Datamaster does not give total advance on cars where initial advance can be set via the distibuter.
Old Jul 30, 2002 | 11:22 PM
kvu's Avatar
kvu
The base timing is already included in the main s/a table.You do have 29 total timing.
Old Jul 31, 2002 | 07:15 AM
Carl90's Avatar
KVU,
Thanks. That means that there is probably more room to play with raising timing.
Carl
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
eduardosac
Sep 16, 2015 02:18 PM
armybyrd
Sep 16, 2015 07:00 AM
angel2794
Sep 8, 2015 06:22 PM
