Idle RPM while in drive (didn't find answer in search)
Old Aug 17, 2002 | 01:08 PM
88_vette's Avatar
FInally got my idle rpm and BLMs looking good at idle, but only in park/n. Once I put it in gear the BLMs change. I knew they would because of load, and I've gotten them close to 128. The problem is the idle speed. I notice on Datamaster that the Idle RPM says 850RPM which I have programed in the chip. But once I put it in gear it wants to idle at 800-700(to low), and Datamaster reports this. How do I change the in gear idle speed using tunercat?
Old Aug 17, 2002 | 03:45 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: Idle RPM while in drive (didn't find answer in search)
In the Constants page, change the 'Idle Speed Adder in Park/Neutral' setting to change the desired setting to whatever RPM to add, or zero if you wish, while in park or neutral.
Then, set the desired idle speed while in drive in the 'Desired Idle Speed vs Coolant Temp.'
When in park a wire, (orange and black I think, don't remember the number) is grounded and that's when the Idle Speed Adder in Park/Neutral comes into effect.
This is assuming your tuning an '88 but I believe other years tune similar.
Old Aug 17, 2002 | 03:47 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Re: Re: Idle RPM while in drive (didn't find answer in search)
[QUOTE]Originally posted by SMasterson
[B]
Oops! Wrong click. . .
specialized
Jun 18, 2022 09:26 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Wade787b
Sep 29, 2015 01:15 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
hokis
Aug 9, 2015 03:57 PM
