what parameters cause spark to be advanced when engine is idling?
Old Aug 23, 2002 | 07:31 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Doing some trouble shooting. Engine surges from 550-800. With base timing connector disconnected, engine is stable. When connected engine surges and you can watch the spark advanced between 2 and 4 degrees. Still surges with IAC disconnected.
Just scanning the tables to see what else (sensors) can make the ECM adjust spark when idling in park when the engine is warm.
I am using WinBin and a 1987 ABWN image.
Tried a 1988 image, same result. Has to be coolant input, or MAF reading.
Scanner shows nothing out of the norm. MAF did seem to jump once and a while.
Going to check fuel pressure, voltage, MAF burnoff and those sorts of oddities tonight.
Mark.
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
