Turning for 700R4->TH350
Old Aug 29, 2002 | 10:04 AM
jnjspdshop's Avatar
I was just wondering if gains can be made in tuning after a transmission swap. I am talking about a speed density motor. Does the VE vs. MAP vs. RPM requirements change? Went from a 700R4 with 2400 stall and 3.27 gears, to a TH350 with a 3000 stall and 3.70 gears. What else can I change to gain improvements
Old Sep 1, 2002 | 02:13 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Turning for 700R4->TH350
You can start at square one with the timing and fuel.
Changing the stall speed alone changes just about all the mid and low range stuff.
The 700 goes from 3.06 to .7 in gear multiplication.
350 has a 2.6 or there abouts first gear, and high gear is 1 to 1.
The engine will be working intirely differently, load wise, and cruise stuff is day and night different. Could wind up being rather large changes.
Old Sep 1, 2002 | 11:44 PM
funstick's Avatar
i have a different opinio that if the tune was right to start with for fuel and spark the only really good place to make change will be in the ve adder tables and pe enrichment. the engine is still gonna need x amount of fuel at x load. cuase its still gonna flow the same amount of air. spark timing might need a tad of tweakign maybe a llittle more advance before teh stall to help with throttle response but i dont think anything to radical.
i would first put in the tranny and see where yr at.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
383cam
Sep 9, 2015 06:01 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
